LS3 accessory drives
Discussion in 'High Tech Retrofits' started by TCinthe6, Dec 17, 2018.
  1. thesalboy
    thesalboy Veteran Member
    373
    130
    Mar 25, 2017
    Los Angeles, CA
    Actually, my hoses are plumbed backwards. I will be re-plumbing for hydroboost. If I weren't, the pressure line would likely be more direct, but the return line would be even trickier to run using these loops given the tight clearance at the reservoir. And someone noted to me that the experts say looping hoses upwards like this a no-no (though I'm not convinced that's really a problem given that I've seen upward loops on production cars).
  2. badazz81z28
    17,358
    598
    Alabama
    Yeah, it doesn’t matter...it’s a hydraulic system, it’s not gravity fed.
  3. thesalboy
    373
    130
    Mar 25, 2017
    Los Angeles, CA
    Well, Tobin at KORE3 says with a 9" dual diaphragm vacuum booster, I should be OK. He a Hydratech dealer, so he easily could have steered me that direction. (KORE3 is by far the best vendor I've encountered on this build.) So stay tuned...
  4. thesalboy
    373
    130
    Mar 25, 2017
    Los Angeles, CA
    Was able to get that fitting out of the plastic reservoir without breaking anything, and re-plumbed my lines - correctly, this time. Details are on my build thread.
  5. QUAKE_WARS
    QUAKE_WARS Veteran Member
    2,025
    149
    Dec 19, 2008
    I have the HOLLEY mid mount. Well worth the Money!!
  6. badazz81z28
    17,358
    598
    Alabama
    ^ it’s a nice system, I couldn’t get over the fact the whole system hangs on the water pump bolts.
    QUAKE_WARS likes this.
  7. QUAKE_WARS
    2,025
    149
    Dec 19, 2008
    I felt the same way. Its actually very well thought out and well designed unit.
  8. badazz81z28
    17,358
    598
    Alabama
    I like it too, I just have this weird compulsive disorder for no reason at all.
  9. QUAKE_WARS
    2,025
    149
    Dec 19, 2008
    Would you Like to join my CLUB lol.
    By the way, Do you have any updated pics of your car.. its always been BADAZZ
    You have a PM.
  10. TheMeat
    TheMeat Veteran Member
    970
    Feb 9, 2007
    Ol' Miss.
    Love the Holley drive system but, I am also worried about that water pump. If/when that pump fails, where would you get another? Hope Holley carries it for life. Good looking system for sure.
    Thesalboy, glad that fitting came out...made a huge difference in plumbing for you.
