Ls3 pedal mounting..
Discussion in 'High Tech Retrofits' started by 408maro, Dec 18, 2016.
  1. 408maro
    408maro Veteran Member
    1,618
    Nov 27, 2008
    San jose,CA
    How did you'll with corvette pedal mount it?
    Thank you
  2. badazz81z28
    14,185
    110
    Las Vegas, NV
  3. 408maro
    1,618
    Nov 27, 2008
    San jose,CA
    that bracket is for a different style pedal.. may work with fab work, but dont have a welder to do all that.. looks like DSE makes one but only for a 1st gen..
    ironworks makes one for a different pedal aswell
  4. badazz81z28
    14,185
    110
    Las Vegas, NV
    Use the pedal with the scarebird kit.
  5. 408maro
    1,618
    Nov 27, 2008
    San jose,CA
    thank you.. i will give them a call and see if they have any ideas on the wiring.. looks like it is different and may not work, dont really want to cut my PSI harness
  6. badazz81z28
    14,185
    110
    Las Vegas, NV
    If its the same pin, it should work. But worst case, re-pinning a GM connector is easy. Scare bird will know for sure.
  7. CAMeeks
    CAMeeks Veteran Member
    502
    Jan 5, 2014
    Deer Park, TX
    Any pics of the installs and pedal?
  8. daniel76309
    daniel76309 Veteran Member Lifetime Gold Member
    902
    Oct 22, 2005
    Niceville, Florida
  9. CAMeeks
    502
    Jan 5, 2014
    Deer Park, TX
    There is one made for Fbodies
  10. 76_TypeLT
    6,385
    132
    Jul 26, 2008
    Houston, TX
    FWIW, here is an album with some pics of the gas pedal installed using the Scarebird bracket.
    http://imgur.com/a/ifKUM
