LT-1/LS-1 swap links topic
Discussion in 'High Tech Retrofits' started by Skaal-tel 79, Jan 18, 2006.
  1. triumph
    triumph New Member
    16
    Jun 3, 2008
    Los Angeles, CA
    I think the iron block might give it away...
  2. KansasTwister
    KansasTwister Veteran Member Lifetime Gold Member
    1,389
    Oct 7, 2006
    Lawrence, ks
    Are your techs that smart? Im 18 and ive outsmarted several gm techs. Didnt some of the 5.3, 6.0 and 6.2s come in aluminum blocks? I thought only some were iron??? maybe im just crazy (most likely) I havent reserached the 5.3 and so motors too well so dont quote me.
  3. nobreaks254
    nobreaks254 Veteran Member
    494
    9
    Jul 14, 2007
    aberdeen, SD
    There are some aluminum 5.3 truck motors but not 6.0.
  4. nuttyprofessor
    nuttyprofessor Veteran Member
    146
    Sep 27, 2008
    cream ridge, nj
    how did you work around teh drive by wire of teh LS1?
  5. PolarBear
    1,189
    Apr 24, 2008
    NJ
    f-body ls1 is drive by cable
  6. rscamaro73
    rscamaro73 Administrator Staff Member
    14,966
    9
    May 30, 1999
    Striking fear and destroying the enemy
  7. PolarBear
    1,189
    Apr 24, 2008
    NJ
    Regarding the 3rd gen sender in the 2nd gen tank, will the late 3rd gen sender fit in ALL year 2nd gen tanks, or specific ones? The guide referenced above does not specify. Found a nice used sender from a 3rd gen that I think I want to grab but if it wont fit in my early style tank I dont want to waste the cash
    Thanks
    James
  8. BonzoHansen
    19,398
    775
    Jun 1, 2005
    Scott from Hamilton, NJ
    Look up sender part #s and see if it changed. Maybe on rockauto or something. That should answer your question.
  9. Knuckle Dragger
    14,761
    1,300
    Nov 2, 2002
    Waddell AZ
    No it won't fit all tanks. IIRC it fits the 70-73. After that the hole is too small.
  10. PolarBear
    1,189
    Apr 24, 2008
    NJ
    Thanks, that what I thought. When I helped my friend with the tank on his 79 I didnt think it looked like it would fit but that was way
