LT-1/LS-1 swap links topic
Discussion in 'High Tech Retrofits' started by Skaal-tel 79, Jan 18, 2006.
  1. Burt
    Burt Veteran Member
    453
    Feb 17, 2005
    Far Northern CA., USA
    Aces (or anyone),
    Do you know where I can find the detailed info on the Spectra GM42AFI Tank and Pump? I went to Rock Auto and found the listing, but I couldn't find any specs, etc. This looks like it makes more sense than going through the hassle of modifying the stock tank and cost of a new pump, etc.
    Thanks in advance,
    Jim
  2. sbca96
    sbca96 Veteran Member
    2,896
    Oct 25, 2004
    Santa Barbara, Ca
  3. whitesparts
    whitesparts New Member
    Mar 23, 2012
    couch mo
    www.lt1swap.com
    he help me out on my lt1 s10 swap and my ls 4.8 swap in my 56 chevy
  4. Jones20992
    Jones20992 Member
    95
    Apr 30, 2012
    Casper wy
  5. sevitz5
    sevitz5 Veteran Member
    1,618
    Feb 27, 2011
    Middle Point, Ohio
    Here is a list of items I used in my swap:
    I have compiled this list of what I have bought for my conversion, and have tried to list part numbers and where to purchase. I hope this helps someone looking for a part.
    Here goes:
    2001 Silverado 2500 6.0 30,000 miles...Local Junk yard $700
    2006 GTO T56 6 speed 10,000 miles...Local junk yard $1,700
    Texas Speed MS4 Cam (239/242 .649/.609)....25-MS4 $400
    LS6 Intake with fuel rail....Ebay or LS1Tech $400
    LS2 Timing chain...GM Dealer 12586482 $75
    Texas Speed LS6 ported oil pump...25-LS6PORTEDPUMP $190
    1999 Fbody oil pan,win tray, pickup tube...GM dealer $350
    Car Shop 1" setback motor mount plates...CSP2370 $50
    2000 Camaro alt...NAPA NNE-1N4742 $180
    2000 Camaro harmonic balancer...NAPA NOE 6005281 $65
    2000 Camaro water pump...NAPA TFW 45002 $130
    EFI Fuel Tank...Rock Auto GM42AFI $375
    2000Corvette fuel filter w/return...Ebay, Wix 33737 $40
    Fitting's for fuel filter...Russel...640850, 640860, 640940 $45
    LS1 polished throttle body...Ebay (swap program you send him yours) $60
    Pushrods...Texas Speed 25-7400 $90
    Heads 243 casting w/.650 springs....LS1Tech $675
    LS7 Clutch press, flywheel....LS1Tech $260
    Tick Performance adj clutch master cyl...TAMCKFB $325
    Tick Performance slave and throwout bearing...24264182 $130
    Tick Performance speed bleeder...TPSBL $50
    Allen head Engine bolt kit...Ebay $35
    Allen head Intake bolt kit...Ebay $30
    Stand alone wire harness....Done by local guy $200
    Clutch master cly mounting plate...Detroit Speed 070430 $30
    Serpentine belt...O'Rileys...Gates K060547 $20
    Idler pulley...O'Rileys..38008 $15
    2000 Camaro Belt Tensioner...NAPA NBH 38195 $43
    Upper radiator hose...NAPA Gates 22352 $20
    Lower radiator hose...NAPA Gates 20734 $13
    2000 Camaro starter...NAPA BSN SR8581N $180
    2000 Camaro Thermostst...NAPA THM 400186 $16
    Spark plug wires...Jegs Taylor 10.4mm $90
    Spectre Performance cold air kit...900134 $208
    G-Force crossmember....RCF2E-T56 $290
    Texas Speed Racetronix 42lb injectors...135-01D030X-1 $350
    Flywheel & pressure plate bolts...Jegs $62
    Oil catch can...Ebay $40
    -6AN Fuel line and fittings...Aeroquip $220
    Lokar throttle cable...Jegs TC-1000LS!U $55
    Lokar oil dipstick...Jegs ED-5008 $58
    Lokar Throttle brkt...Jegs TCB-40LS13 $38
    Valve cover breather...Metco Motorsports MBR0003 $35
    2000 Silverado 2500 oxygen sensors (2)...NAPA BSH-13026 $110
    Fuse block for fuel pump, fans, etc...Local junkyard 99 Monte Carlo. $20
    LS7 MAF sensor....GM Dealer 15865791 $70
    Shorten driveshaft to 44 5/8"...Local shop $130
    4.10 rear gears...Summit $187
    Headers and exhaust....Stainless Works.
    I hope someone can use this list, I wish there was a list like this before I started. LOL.
  6. hullj21
    hullj21 Member Lifetime Gold Member
    53
    Feb 12, 2012
    Brownsburg, In
    :confused:
    :confused: 5.3L bored out to LS1 specs ... can you even do that ? holy sh.t did I just read that right ? now the gears are really spinning......
  7. Leonards78LT
    Leonards78LT Veteran Member Lifetime Gold Member
    1,031
    Jan 21, 2001
    Central Oklahoma
    Yep, exactly what I did. Read my sig. :)
  8. Shabba
    Shabba New Member
    Nov 12, 2013
    FL
    Would this swap (LT1 into '79) be too difficult for someone who has never done a motor swap before? I worked on cars and know my way around cars pretty well. I am pretty confident I could figure out how to do this swap from common sense and reading threads but the wiring and fueling scare me a little.
  9. stroked383
    stroked383 Veteran Member Lifetime Gold Member
    764
    Jul 18, 2011
    Saugerties, NY
    Don't let the wiring scare ya, there's a lot of info out there even a step by step on the wiring. Check out www.lt1swap.com great info there
  10. Shabba
    Shabba New Member
    Nov 12, 2013
    FL
    Thanks that's what I was hoping to hear. Another question; not including the price of the shell and motor/trans/ecu, how much should I budget for parts needed to put the motor in?
