Lt1 headers?
Discussion in 'High Tech Retrofits' started by Spot_remover, Aug 19, 2009.
  1. Spot_remover
    Spot_remover Veteran Member Gold Member
    853
    Aug 24, 2008
    Murrayville.Ga
    What headers are you guys using for LT1s or will regular SBC headers work? Of coarse i mean what headers will fit well in our 2nd gens with LT1s
  2. sbca96
    sbca96 Veteran Member
    2,897
    Oct 25, 2004
    Santa Barbara, Ca
    The LT1 has a D port exhaust, so regular SBC headers will not work. That is
    what I know, to add to the above question, are there any California smog legal
    exhaust headers that fit an LT1 in a 2 gen? (pipe dream huh?)
    Tom
  3. Ca-ma-ro
    Ca-ma-ro Member Lifetime Gold Member
    87
    Dec 22, 2008
    Texas City, TX
    I used Hedman Hedders pn:65104 for a SBC in a Camaro with 1 3/4" primaries and 3" collector. They did not fit perfectly, I had to modify the angle of the flange on the driver's side to clear the steering shaft and lower control arm bracket. I ground the flange off the headers, rolled the header in toward the motor, tacked them, and then did a final weld on the gasket side. Although you could just dent it a little for clearance, I didn't want dents in my headers, so I did it the "hard" way.
    BEFORE: In the first pic, the header is not tightened because it would contact the steering shaft, the second pic shows it contacting the control arm bracket.
    AFTER: Shows about 1/4" of clearance at the steering shaft and clears the control arm bracket by about 3/8" fully tightened.
    If you'd like a more detailed explanation of what I did, let me know.
    BTW: The passenger side fit with no modifications. And once installed, both tucked up nicely beneath the car, so speed bumps shouldn't be TOO big a problem...
  4. Spot_remover
    853
    Aug 24, 2008
    Murrayville.Ga
    Wonder if a set of block huggers for a 4th gen, would fit with no further modifications?
  5. Ca-ma-ro
    87
    Dec 22, 2008
    Texas City, TX
    I've heard the shorties are better for clearance, but can't comment on that since I wanted long tube from the get-go...
  6. 91chevywt
    91chevywt Veteran Member
    206
    May 27, 2008
    South Jersey, NJ
    Small block chevy headers fit. I'm running them. I haven't had the car on the dyno but it does run like a raped ape. I'd imagine any header will perform better than the stock exhaust manifolds. Plus they will fit nicely.
  7. 77LT1
    77LT1 Veteran Member Lifetime Gold Member
    719
    Jan 29, 2007
    Jax, FL
    I'm using my old Hedmans I had on my car with the Gen I 350 I use to have. No issues at all and if it fit before it should fit after it's still a small block Chevy after all.
    B
  8. LT1 WS6
    LT1 WS6 Veteran Member
    510
    May 25, 2009
    Sandy Springs, GA
    The headers just need to be 1-3/4" primary to guarantee they'll cover the exhaust ports. As mentioned, the LT1 has a D port for the exhaust. There may be some 1-5/8" primary non D port headers that will work but I don't know of any.
  9. 3_z28camaro
    3_z28camaro Veteran Member Lifetime Gold Member
    4,447
    Dec 17, 2004
    Acton, CA
  10. Desert_Dick72SS
    Desert_Dick72SS Veteran Member
    197
    Feb 10, 2009
    San Francisco Bay Area
    I used Hedman #66609 (same as 68609?)
    These are coated shorty headers,1-5/8", coated, but they are specifically for D-Port small block angle-plug in 67-81 camaro.
    They fit perfectly and have lots of ground clearance, but would interfere with clutch linkage if you have a stick (unless you went to a hydraulic)
    I have a ZZ383 with Fastburn Heads, D-port like the LT-1, in my '72.
    $459 at Summit:
    http://www.summitracing.com/parts/HED-66609/
    -Rich-
