Lt1 headers?
Discussion in 'High Tech Retrofits' started by Spot_remover, Aug 19, 2009.
  1. Christian GM
    Christian GM Veteran Member
    146
    Jul 14, 2007
    Italy
    I've the uncoated 68609 on mine.
    they fits really web, in my work in progress process today I plan to install the 2,5" Magnalow system :)
    I just found they're too close to the OEM A/C air box on the right side, I had to look better for a solution...
    maybe this evening I will post some pictures.
    bye!
  2. 1981LT1
    1981LT1 Veteran Member Lifetime Gold Member
    528
    83
    Dec 15, 2004
    San Antonio, Tx, USA
    Wrong. You get the headers to fit the chassis, not the engine. And regular SBC headers will work. I have used, Hedman, Summit, and Hooker SBC headers on my LT1 and non of them have given me any problems. I am running 1 5/8" headers for my application and I am putting 360 hp at the wheels on a stock CID and stock bottom end.
  3. sbca96
    sbca96 Veteran Member
    2,897
    Oct 25, 2004
    Santa Barbara, Ca
    Wrong. Headers are useless if the flange blocks 25% of the port opening. If
    your header flange port hole is larger than the LT1 port, then its golden. When
    I got my '95 Impala SS, it had AS&M headers on it, FOR an LT1. Problem was
    they used square port gaskets, which blocked 25% of the port opening. The
    headers were melting just about everything in the engine compartment so I
    traded them for some stock Impala SS manifolds, and did some hand porting
    to open them up a bit. I picked up a nice seat-of-the-pants improvement. If
    you get the wrong headers, you might as well stick to stock manifolds.
    Tom
  4. Christian GM
    146
    Jul 14, 2007
    Italy
    QUESTION:
    I have the Hedman p/n 68609, and on the passenger side they're so closest to the A/C case. about half an inch. any idea to don't burn out the case?
    thanks!
  5. Christian GM
    146
    Jul 14, 2007
    Italy
    UP!!!
    Thanks!
  6. SomeGeoffGuy
    SomeGeoffGuy New Member
    22
    Mar 15, 2010
    Metro Detroit
    I would just put some header wrap on them locally. It looks like crap but it works well.
    -Geoff
  7. Christian GM
    146
    Jul 14, 2007
    Italy
    yeah..
    they're ugly :(
    they need to be wrapped on both sides of the engine for "thermo balancing"?
    or I can use them only on passenger side?
    bye
  8. SomeGeoffGuy
    22
    Mar 15, 2010
    Metro Detroit
    If you were just doing a a couple inches on one tube I wouldn't worry about the balance issue. I had a Grand Prix GTP where I just wrapped the crossover where it came under the throttle body. It worked like a charm.
    -Geoff
