LT1 T56 on Non LT1 Small Block
Discussion in 'High Tech Retrofits' started by Kyle C, Aug 5, 2006.
  1. Kyle C
    Kyle C Member
    77
    Sep 24, 2002
    Sanford, NC
    While I T56 bolted to a bear block and install for xmember and tunnel fitting I noticed that the clutch fork works ass backward from the M21 I took out. I am assuming the TO bearing and PP work differently than the non LT1 stuff. Will the LT1 PP bolt to a standard small block flywheel?
  2. AJ_72
    AJ_72 Veteran Member
    5,129
    Jul 3, 2003
    Chebanse, IL USA
    It will bolt to a one piece seal crank, but not a two piece.
    Different bolt pattern. 3" instead of 3.58" like the two piece cranks.
  3. Todd80Z28
    11,569
    245
    Jun 11, 2002
    Northern VA
    It won't bolt to any old flywheel, not even the one-piece. You need a flywheel specifically for LT1 transmissions.
    As you noticed, the fork is backwards. That's because the pressure plate works backward. The Throwout bearing pulls on the diaphragm fingers to lift the pressure plate, instead of pushing like normal clutches do.
    Because of this, the disc also goes in backwards. The center springs face the block, instead of the transmission. As such, the flywheel is much deeper in the center, to allow room for these springs.
    You can either use a custom flywheel (aftermarket only) with the factory clutch parts (LT4 or aftermarket stuff preferred), or you can start searching out some custom bellhousing solutions.
  4. jakeshoe
    8,883
    21
    Dec 8, 2000
    Republic of Texas
    Or you can use the stock bellhousing, conventional flywheel and pressure plate, and a hydraulic throwout bearing.
