m22Z autogear
Discussion in 'Transmission & Driveline Topics' started by David Miotto, Sep 16, 2019.
  1. David Miotto
    David Miotto New Member
    Dec 6, 2018
    Would love to hear any opinion regarding ;
    1970 z28 c/w m20 , 3:73 , 3000 rpm at 60 mph ,not very highway friendly.
    trying to decide to go to a m22z auto gear c/w with a 3:23 rear ratio.
    approx. 2450 at 60mph.
    Will obviously keep the m20 and 373 for the originality,but want a little more hwy cruise comfort with the new setup.
    Should still have nice punch out the hole with new setup.
    Bottom line close to $5 grand for 500rpms ??
    David
  2. G72Zed
    G72Zed Veteran Member
    1,080
    235
    Sep 8, 2015
    For that initial cost, perhaps a 5spd w/OD would be a potential option to look into. keep your rear end/gear intact.
  3. big gear head
    big gear head Veteran Member
    6,175
    78
    Jul 30, 2001
    Central City, Ky.
    I'm running a M23Z in my Camaro with a 3.70 gear and 31 inch tall tires. Works well for me.
  4. COPO
    17,685
    683
    4th gear is 1:1 ratio in the M20, M21 and M22 factory Muncie's. I take my daily driver for long highway runs instead of my 70 Z28 and I won't cut the floor for a 5 spd. I've owned mine since 1981, why change now is what I tell myself.
    $5 G's for 500 rpm, that isn't the way to go. With that 5 Grand, if I were you, I'd buy a 5 speed.
  5. czizza
    czizza Veteran Member
    1,007
    52
    Jan 8, 2004
    N. Massapequa, NY, USA
    I had a 79 with ST10 and 3.73 first gear was 2.82; I swapped out for a TKO500 a new cross member and driveshaft and I have .68 OD ... it is strong enough for me to drop the clutch at 5K and pull the wheels up 2-3 inches.
    dave@ztech likes this.
  6. 76z28
    76z28 Veteran Member
    2,006
    46
    Jun 29, 2009
    bakersfield
    I love my 6 speed :D
  7. Dave Nelson
    Dave Nelson Veteran Member
    4,265
    1,991
    Dec 19, 2003
    Vineland N.J USA
    Keep the Muncie and go with 3:07 or 3:08 gears.
  8. xten
    xten Veteran Member
    2,800
    1,559
    Sep 24, 2014
    Pittsburgh, Pa.
  9. Dave Nelson
    4,265
    1,991
    Dec 19, 2003
    Vineland N.J USA
    Keep in mind if you go with Gearvendors you will need to cut the tunnel brace for clearance.
  10. G72Zed
    1,080
    235
    Sep 8, 2015
    That combo would give an overall first gear ratio of 6.77, not good, but 4th gear with the 3.08 would be great.
    That's why I mentioned the 5spd w/OD. The Richmond SS or TKO600 would be like having a 4.85/88 first gear and a 2.87 in 5th for the Richmond, or 3.06 with the TKO's .82 OD.
    And for the extra $750 vs the GV, no floor cutting/pinion angle issues with the Richmond.
