Major Clutch Issues!! 71 W/ Muncie 4 SPD
Discussion in 'Troubleshooting & Diagnosis' started by '71StreetZ, May 15, 2019.
  1. '71StreetZ
    '71StreetZ Member
    53
    Aug 18, 2017
    Hi all, my 71 has been having major clutch issues since I switched from a Saginaw to a Muncie. The car has an M21 10/27 spline trans a GM 6263756 truck style bell housing, w/ alum adapter ring to use 4 1/8” nose cone, 12” three fingered clutch and a self aligning throwout bearing
    Whenever I push the clutch in it sqeals at the bottom of the pedal or it makes this hideous clunking sound I’ve had two different throw out bearing in it the first came apart in minutes and the second one has lasted for a bit but always makes a squeal or won’t fully disengage.
    I have no idea what’s causing this but it just seems ridiculous I’ve put a new clutch fork pivot ball and throw out in the car but just can’t seem to get it all to work properly
    I’ll attach the photos of clutch, bellhousing, and throwout that I have
  2. mech393
    mech393 Veteran Member
    825
    13
    Aug 9, 2003
    belvidere illinois usa
    you should buy a bell housing used with the Muncie trans , I believe it s 621 bell housing . the truck bell housing may be to shallow to allow the throw out bearing to move freely and causing it to bind.
  3. 70lt1z28
    2,852
    447
    Oct 3, 1999
    Beavercreek, Ohio, USA
    That's a weird bellhousing. does the lower right bolt even lone up with the trans? Looks like it is too far to the right compared to the lower left hole.
  4. Zspoiler
    Zspoiler Veteran Member
    2,987
    206
    May 6, 2012
    Federal Way, Washington
    It sounds like the bellhousing is out of line .I have had similar problem using a scattershield . I would have the alignment checked and or replace the bellhousing with one for a car.
  5. COPO
    17,196
    457
    Check the total height of the pressure plate, it could be the wrong length from the face to the end of the fingers.
  6. '71StreetZ
    '71StreetZ Member
    53
    Aug 18, 2017
    The bell housing bolts do line up with the trans the bell housing has been on the car previously with a Saginaw trans with the same clutch and as far as I know it is one of the only ones that will fit a 12” clutch alignment of the bell housing is also good I have a spare input shaft and bearing retainer that I’ve used as an alignment checker as well the bellhousing is the same depth as a smaller spare that I have for a car but the spare won’t fit the clutch
