Mallory or MSD
Discussion in 'Engine Topic' started by 87zz28, Oct 3, 2016.
  1. 87zz28
    87zz28 New Member
    8
    Oct 3, 2016
    I'm looking to get a new ignition set up for my new 350 and I dont know what brand to go with. I have tried doing some research on MSD vs Mallory but everything I have seen was posted before 2012 and since then MSD bought Mallory and a few other companies. So what is the difference between the stuff anymore? I'm between a MSD 6al and Mallory HyFire VI-AL. I have heard alot of bad things regarding MSD products being junk now. But everyone says MSD is the way to go but I read some good stuff about the Mallory too. Is the stuff any good since MSD took over or is the relablility the same now?
  2. COPO
    18,067
    872
    Made in China junk today. The new digital 6AL's are lucky to last 11 months, some DOA. Better read up on the reviews where the boxes have left people stranded. Best to keep a set of points/condensor in the glove box. I'd like to pick up an analog 6AL from 10-15-20 yrs ago, not today's crap.
  3. Zspoiler
    Zspoiler Veteran Member
    3,312
    273
    May 6, 2012
    Federal Way, Washington
    You can check on Crane Cams ignitions boxes as well
  4. mrdragster1970
    7,822
    507
    Apr 12, 2007
    The class I race is full of $100,000 cars, and everyone of them has MSD, so somebody still likes what they're putting out??
  5. night rider
    night rider Veteran Member
    6,401
    Aug 6, 2002
    Bremen, Ga
    I run a Mallory digital 685 box, MSD pro billet dist., Mallory E-core coil, MSD 8.5mm plug wires.
  6. Bumpad_Z28
    Bumpad_Z28 Veteran Member
    500
    Apr 9, 2004
    Logan, UT
    MSD > Mallory
  7. Turbo70Camaro
    2,146
    117
    Jan 7, 2005
    so cal
    You can try Daytona sensors for one or Crane.
  8. CorkyE
    10,453
    508
    Here is what MSD has posted; Stay tuned as we bring Mallory ignition and distributor lines back! That said, I've had good luck with my Mallory 685 box. The rpm window switch, timing retard, and 2 rpm limiters come in real handy for single stage nitrous use. And like Mr Dragster says, MSD is king on the dragstrip. There is going to be failures in just about any ignition system and a good many are self induced.
    https://www.msdperformance.com/brands/mallory/
  9. grzewnicki
    3,448
    175
    Dec 9, 2009
    Gordon from Jacksonville Fl
    Running MSD 6 and MSD dist for 2 years now, no problems.
    ratpatrol71z28 likes this.
  10. muscl car
    21,807
    701
    Jul 8, 2001
    High Desert of Hesperia Calif
    MSD 7AL2 ignition box , MSD 8251 coil , , upgraded Mallory mech adv Unilite and Accel 8.8 wires
