Master Cylinder Question
Discussion in 'Troubleshooting & Diagnosis' started by mallard, Jul 9, 2019.
  1. mallard
    mallard Veteran Member
    470
    88
    Oct 3, 2013
    SK, Canada
    My 74 Z needs a master cylinder. Although everything works fine (no fade or spongy pedal yet) it's developed that patented leak between the cylinder and the booster. It's been nearly 40 years since I've gotten a replacement cylinder for anything so my question is what are the experiences with replacements? The picture of what Amazon sells looks much like factory original. While I like the idea of the stock look, it's hardly a deal breaker.
    I have a good used MC from a 74 that I dismantled nearly 30 years ago but I'm reluctant to go that route for something that critically important.
    What are the experiences?
  2. Gary S
    22,298
    720
    If you look hard enough, you might be able to find rebuilt original ones yet, but rebuilds are a bit risky unless you know for sure that they were bored and sleeved. Usually after that many years they fail due to corrosion in the bore. Any left over pitting in the bore can make them less reliable after the rebuild. You can also find new ones made later. They will be a bit different in appearance. Usually the new ones don't have the bleeders that the old originals had, but you don't need them.
  3. shanghai Kid
    shanghai Kid Veteran Member
    148
    58
    Jul 5, 2010
  4. TommyRS70
    TommyRS70 Veteran Member
    1,146
    93
    Jan 31, 2004
    KY
    Steve Gregori, brakebooster.com is a stand-up guy. Replated and rebuilt my original booster. Also clear zinc plated a number of other parts. Nice work!
    shanghai Kid likes this.
  5. mallard
    470
    88
    Oct 3, 2013
    SK, Canada
    Hopefully I won’t need a booster just the mc. Just curious if posters have had good luck with amazon or other similar quality MCs.
  6. Gary S
    22,298
    720
    Every time I've replaced a master cylinder, I got mine from my local auto parts stores. I've had great luck with them....no failures, but buying local gives me a place to go if there was ever a problem.
  7. 2hipZ/28
    2hipZ/28 Member
    30
    Sep 4, 2006
    illinois
    Ugh , I wish I could say the same about having good luck . I went through 2 brand new MC form O'Reilly's that leaked but the 3rd MC from NAPA was a charm. I bench bleed all 3 being very careful not to push in more than 1" and getting all the air bubbles out. The first 2 leaked at the rear seal after I installed them.
    I gravity bleed all 4 wheels keeping an eye on the reservoirs so they stayed filled with brake fluid. The rear drums were fine but I had to use the vacuum pump on the front discs.
    I agree with Gary about buying local, O'Reilly's refunded my money.
  8. kenny77
    kenny77 Veteran Member Lifetime Gold Member
    2,689
    11
    Jul 31, 2001
    Ft. Lauderdale, FL
    NPD National Parts Depot for this. I got the original style with the bleeders. They have an Orlando location and I get parts from them in 1 day. No really......1 day Check those rear wheel cyls too. I had the leak at the back of the booster, then both rear cylinders
  9. Twisted_Metal
    26,875
    904
    My son and I got NEW (not remanufactured) master cylinders from NAPA.
    Mine worked very well.
    His leaked from the rear while bench bleeding.:(
    He took it back and the second one was good.
  10. bodymanbill
    bodymanbill Veteran Member
    1,235
    592
    Feb 1, 2007
    South Park Pa
    image.jpg Got mine for my 73 from Summit, MC and booster was only around $100 I think. Have around 500 miles on it so far, been perfect
