Mechanical Parking Brake
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by 3_z28camaro, Mar 24, 2006.
  1. 3_z28camaro
    3_z28camaro Veteran Member Lifetime Gold Member
    4,447
    Dec 17, 2004
    Acton, CA
    I am close to completing my C5 disc brake conversion and since the rears do not have the ability to use the stock C5 parking brake drum. I was wondering if anybody knew of someone that makes mechanical parking brakes for our 10-12 bolt rear ends. Otherwise I guess I will use a line lock even though that is not exactly what they are supposed to be used for.
    Something like this, except for our rear ends:
    http://www.ecihotrodbrakes.com/mechanical_parking_brake_system.html
    Thanks for any help!:bowtie:
  2. Gary S
    20,140
    66
    Neither a line lock or a brake attached to the drive shaft are legal for passenger cars and light trucks. If you have to pass any kind of inspection, these items will force you to keep your car off the roads.
  3. SMH 383SBC
    SMH 383SBC Veteran Member
    273
    Mar 9, 1999
    Southeastern, OHIO
    me too.
    I am in the same boat. I am looking for some kind of e brake also. Hopefully someone here can give us some good advice.
    thanx
    s
  4. GetMore
    2,870
    Nov 8, 2004
    Patterson, NY
    One of the brake companies makes a small parking brake caliper. SSBC or Wilwood, I think.
    It's an add-on to their normal system.
  5. 3_z28camaro
    4,447
    Dec 17, 2004
    Acton, CA
    I will look into SSBC or Wilwood.
    Otherwise this is a shameless attempt to bump my own topic.:innocent:
  6. SMH 383SBC
    273
    Mar 9, 1999
    Southeastern, OHIO
    Found a mechanical ebrake
    http://www.precisionbrakes.com/
    scroll down to new products.
    price is steep though.
    Parking Brake Caliper Features:
    Modern, needle-thrust bearing, low friction mechanism
    Computer-aided design and manufacture
    80:1 (or higher) mechanical advantage in most applications
    Sleek, elegant appearance
    Attractive, durable black anodized finish with stylish CNC-engraved Precision Brakes Company logo
    High strength aircraft alloys
    Uses standard performance caliper brake pads
    Fast and easy pad wear adjustment
    Fits rotors from 11 to 16 inches in diameter and 3/8 to 1 1/4 inches thick
    Fast and easy installation
    Two position forward or rear pull lever
    Reversible lever offset increases mount flexibility
    Custom mounting brackets available
  7. 3_z28camaro
    4,447
    Dec 17, 2004
    Acton, CA
    Thanks, that is what I am looking for, but that price is steep.:eek: Defiantly have to save up for something like that. Thanks again.
  8. John Wright
    13,881
    33
    Aug 9, 2002
    Rustburg, Va
    Kore3 is developing the ebrake for the C5 on our cars...they just haven't added it to their website yet. Last time I spoke with Tobin he said two to three weeks...but that was two to three weeks ago...so should be seeing something soon. He said he had sent all of the parts off to the plater and hadn't got them back yet when I spoke with him.
  9. 3_z28camaro
    4,447
    Dec 17, 2004
    Acton, CA
    Whoa, it is my old thread back from the dead. I knew about the Kore3 parking brake for some time now, they have been developing it for a long time. Over a year I think...
