Metal prep after blasting for epoxy
Discussion in 'Body Restoration' started by sbauerz28, Dec 19, 2015.
  1. sbauerz28
    sbauerz28 Veteran Member
    122
    Jul 5, 2011
    Owego, NY
    I should be to the point soon of having my shell ready to sandblast and spray with epoxy. I think I'm getting some conflicting information about how to prep the metal after blasting. I'm unsure if I need to wipe the shell with a metal prep, or if it is acceptable to epoxy directly over a sandblasted surface? Is the surface finish after blasting acceptable for proper adhesion?
  2. Twisted72
    Twisted72 Veteran Member
    309
    48
    Nov 8, 2015
    New Albany, Indiana
    think I would still blow all the sand or media out of the shell (its get every where like inners of the rockers) then wipe it all down cause of the dust
  3. sbauerz28
    122
    Jul 5, 2011
    Owego, NY
    When I blast the car, the rear quarters, rockers, outer roof skin, and outer door hinge panels will be off. This should minimize the amount of trapped sand.
    I've got some that say I need to wipe with metal prep first and some say that it's not needed.
  4. Twisted72
    309
    48
    Nov 8, 2015
    New Albany, Indiana
    well as the saying goes paint is 95% prep and 5% spray ..I would wipe down ..great job on your build btw.
  5. Z28zz383
    Z28zz383 Veteran Member
    807
    11
    May 11, 2012
    Florida
    If it is real fresh sand blasted metal, epoxy right over after a wipe down with prep sol. Let it sit for overnight or longer, then better use an anti corrosive surface prep. Ospho is a good one.....
  6. 76_TypeLT
    6,389
    144
    Jul 26, 2008
    Houston, TX
    I'd blow it off really good, use a tack rag to remove any other particles, wipe down with a wag & grease remover and maybe do a light tag rack before spraying. I wouldn't use any "metal prep", acetone, thinner or anything besides W&G remover. Some might say to not even use that, but I'd rather wipe the metal down with SOMETHING.
  7. Rick WI
    Rick WI Veteran Member
    10,400
    Jul 9, 2001
    Madison, WI
    You need to whipe down. Process will be laid out within the P Sheet you receive with the epoxy. Want the epoxy to stick? Follow the P Sheet.
  8. perkalator
    perkalator Veteran Member
    1,025
    89
    Aug 27, 2014
    kennewick wa
    This
  9. Z28zz383
    807
    11
    May 11, 2012
    Florida
    Best answer. Always follow the application guidelines laid out by the mfg...
