methanol alky on the streets
Discussion in 'High Performance Modifications' started by mcg1968, Jul 29, 2008.
  1. mcg1968
    mcg1968 New Member
    Jul 29, 2008
    BALTIMORE,MARYLAND
    whats the thoughts on running methanol on the streets in my 78 camaro with 496bbc 15:8 to 1 pro and cons
  2. gregh
    gregh Moderator Staff Member Lifetime Gold Member
    Con: really big fuel lines, all steel too & a extra big fuel tank too since you'll be chewing it up at almost twice the rate.
    Oil changes have to happen very often & you can't park the car for a few weeks between drives without draining & flushing the lines.
    There are a bunch of con's & only a few Pro's. ie, lower running temp, clean burning, almost detonation free, ect.
  3. scrapmetal
    scrapmetal Veteran Member Lifetime Gold Member
    1,716
    Jul 5, 2007
    Cleburne,Texas
    con:having a fuel tanker follow you arround
  4. mrdragster1970
    Agree,
    Con: volume & maintenance will be a pain in the butt for a street car. E-85 would be more forgiving, except if you have a true 15.8-1. Good luck.
  5. 79Z-28
    79Z-28 Veteran Member Lifetime Gold Member
    1,188
    Dec 28, 2004
    Crandall, TEXAS, USA
    Don't forget a really good gas mask.
  6. dcozzi
    dcozzi Veteran Member
    2,130
    21
    May 1, 2002
    Phoenix, AZ
    Methanol will eat rubber parts in your fuel system like Holley needle seat tips and some rubber lines IIRC.
    Power valve is 2.5 times as big and it will suck fuel like a paid pro, as previously stated in the thread.
