Might be good - new fenders
Discussion in 'Body Restoration' started by Chuck71RS, Sep 25, 2017.
  1. Chuck71RS
    1,502
    203
    Nov 24, 2012
    Houston, Texas
    OER is coming out with a new front fender (left and right) for 1970-1977. The below info (Classic Industries) is a pretty darn bold statement.
    I called OER today and was told the fenders are being made with a new stamp using thicker metal. As to when available, OER said indefinite
    Price is $269 per fender (CI and JEGS - only listings so far) which is $78 more then the "X" of AMD and $100 more than Goodmark. Adjust though for JEGS with no oversize truck cost (Goodmark at Summit Racing is $99 and AMD is $110 to Houston) and there is not much cost difference.
    Will hold off for as long as I can to buy these
    3981841B - 1970-77 Camaro Standard Fender - LH - Restorer's Choice
    Restorer's Choice fenders are our Premier grade fender with a fit and appearance that is as close to OE as possible. Each Premier grade fender, produced with high grade factory gauge steel, features the correct cut-out area for the marker lamp. Fit is accurate as are all of factory body lines and contours.
  2. harbone66
    3,499
    286
    Feb 15, 2011
    Central Illinois
    I can remember the Goodmark units from years ago, the fender lip was really weird looking and the fender itself was way to thin.
    hubedobeedo likes this.
  3. cadillac_al
    cadillac_al Veteran Member
    864
    92
    Apr 22, 2015
    Maine
    I hope they are thicker than 22 gauge. I am installing some 22 gauge Jeep fenders and they sure dent easily. Last time I worked on a Jeep they were 20 gauge. I'm getting curious what stock Camaro fenders are now. I'll see if I can find one to measure for the heck of it.
  4. jbloake
    jbloake Veteran Member
    358
    85
    May 1, 2002
    Atlantic Canada
    The difference between 22 and 20 gauge is 0.00625 of an inch . 6 1/4 thousands of an inch . 4 ounces per sq ft.
  5. cadillac_al
    864
    92
    Apr 22, 2015
    Maine
    It doesn't sound like much but every bit helps. 22 gauge feels almost like beer can thickness. The 78 Camaro I checked today is 18 gauge. I hope the repos are at least that thick. They probably are.
  6. 69venture
    69venture Member
    30
    Nov 11, 2015
    Greenville SC
    AMD has a new fender coming available in a few months. I inquired a week or so ago. May be the same source IDK. Good news is something may be available
  7. badazz81z28
    17,421
    605
    Alabama
    We will see....."indefinite"....what's that mean??
    unless they have the OEM crash marks on the top rail...no go for me. I don't like how this feature is missing and it obvious and super easy for anyone to see they are not originals. I hope they also don't have the air cleaner oval indent on the passenger fender
  8. thesalboy
    thesalboy Veteran Member
    373
    130
    Mar 25, 2017
    Los Angeles, CA
    Mine are original - one still has the GM sticker on it even. You want 'em? You should probably first check out my build thread to see what kind of shape they are in.
    I will be getting at least one new fender. I think it's beyond coincidence that both AMD and OER would come out with improved versions and they not be from the same ODM. Regardless, now that Summit charges sales tax, I'll be driving down to CI to pick up the OER Restorer's Choice fender. Will update everyone once I get the fender(s) fitted.
  9. dave@ztech
    3,659
    766
    Mar 27, 2016
    NY
    I think the OER one is AMD's newest fender, the verbage is very similar
    New from Auto Metal Direct, 70-77 Chevrolet Camaro front fenders. Made on our exclusive new tools, each fender is stamped from high quality, heavy gauge steel and features correct cut-out for the marker light. All AMD fenders arrive EDP coated to protect against rust and corrosion.
  10. Lars_2Gen
    Lars_2Gen Veteran Member
    644
    168
    Dec 29, 2017
    Fullerton, CA
    Plus if you look on AMD's site they list CI as carrying their products...
