Might be good - new fenders
Discussion in 'Body Restoration' started by Chuck71RS, Sep 25, 2017.
  1. Lars_2Gen
    Lars_2Gen Veteran Member
    644
    168
    Dec 29, 2017
    Fullerton, CA
    BTW CI is having a "garage sale" Saturday at their Huntington beach location. Wanted to go but have other things to do.
  2. thesalboy
    thesalboy Veteran Member
    373
    130
    Mar 25, 2017
    Los Angeles, CA
    The OER Restorer's Choice fender attempts to reproduce them.
  3. badazz81z28
    17,431
    612
    Alabama
    Hmm, doesn’t look right. It’s a start.
    hubedobeedo likes this.
  4. Lars_2Gen
    644
    168
    Dec 29, 2017
    Fullerton, CA
    So, does that point to the OER fenders actually being made by AMD?
    dave@ztech likes this.
  5. thesalboy
    373
    130
    Mar 25, 2017
    Los Angeles, CA
    The fender came in an OER box, though it was oversized and didn't appear specially designed for the fender (and the only packing was one piece of bubble wrap, so picking up the fender from a vendor is definitely the way to go). So it has not been established whether it is different from the one offered by AMD. I would be very surprised given the facts, though, if it turned out they are not the same fender.
  6. badazz81z28
    17,431
    612
    Alabama
    Can you post more pics?
  7. thesalboy
    373
    130
    Mar 25, 2017
    Los Angeles, CA
    The fender seems to be the same weight and metal gauge as my OE fender, and seems generally well put together. Unfortunately, it is not shaped correctly. It's both too bowed - above and below the body line - and not bowed enough - at the top and bottom. I made a relief cut in the inner structure at the body line, and it helped, but think I will have to relief cut across the entire inner structure to get the over-bow out. Hopefully just bolting it down will take care of the under-bow, but worried that will just cause more over-bow in the middle. The fender-to-door gap is also wrong - tight at the top, big in the middle, and it doesn't follow the front edge of the door very well. Didn't snap a pic, but the repop door is very close to my original OE fender at the gap, so I don't think it's the door, which seems to fit pretty well. Looking at it again now, raising the front of the door might help the front gap. I only worked on this a little, and stopped to focus on my OE passenger side sheetmetal.
  8. Bandit723
    Bandit723 Veteran Member
    3,150
    464
    Oct 1, 2016
    Waupaca WI
    Door to rear quarter panel seems a bit much. Playing with some sims on the underside of the fender may help pull the door to fender gap in.
  9. thesalboy
    373
    130
    Mar 25, 2017
    Los Angeles, CA
    Agreed - the door needs to move back. Right now there is a over 1/2" gap between the firewall mount and fender flange. So everything is too far forward.
  10. krabben1
    8,215
    63
    May 16, 2007
    ( . Y . )Delco
    Does it have a different part number than the befores?
    Im just wondering why they wouldnt try to sell off all existing stock first.
