milodon gear drive
Discussion in 'Engine Topic' started by szalkuskt, May 9, 2017.
  1. szalkuskt
    szalkuskt Veteran Member
    1,368
    Aug 13, 2005
    Honolulu, Hawaii USA
  2. DB Z28
    DB Z28 Veteran Member
    561
    41
    Nov 30, 2003
    Fond Du Lac
    I had one about 20 years ago it was a lot less noisy than a Pete Jackson gear drive. I had no problems with it. After while I took it out did not like the noise .
  3. lumpy12
    lumpy12 Veteran Member Lifetime Gold Member
    727
    15
    Sep 16, 2012
    NorCal
    I ran one on a Pontiac motor years ago. It worked fine for me
  4. fatkid_racing
    fatkid_racing Veteran Member Lifetime Gold Member
    1,049
    90
    Sep 21, 2005
    Saginaw Texas
    Gear drives are good in theory but fail in execution. The only benefit to them is having your cam timing events dead nuts. The huge downside is they transfer engine harmonics into the valvetrain. On a typical street car that's all done by 5k RPM you'd probably never notice any ill effects other than the annoyance of the whine. Start making big power and revving to the moon you'll notice erratic valve lash issues, erratic timing etc.
  5. GoldenOne7710
    4,794
    395
    Jun 23, 2004
    Athens, GA
    Yep. They're about as good as 35" mud tires on a 2WD truck.
  6. Dave Nelson
    Dave Nelson Veteran Member
    4,293
    2,068
    Dec 19, 2003
    Vineland N.J USA
    I agree 100%, go with a good Cloyes roller for no problems.
  7. CorkyE
    10,303
    447
    And this is why the occasional question comes up about gear drives, almost none of us is using one.
