Muncie 4-speed or 5-speed Conversion?
Discussion in 'Transmission & Driveline Topics' started by Billy73, Aug 2, 2019.
  1. Billy73
    Billy73 New Member
    9
    Jul 31, 2019
    I have a 1973 Camaro Z28 with a 383 stroker and the original Muncie 4-speed manual. I sure would like a 5-speed for daily driving. Can I get some opinions about this? For those of you who suggest converting to a 5-speed, what transmission do you recommend? Thanks!!
  2. dave@ztech
    3,427
    712
    Mar 27, 2016
    NY
    I am also looking for a strait swap 4 to 5 , I don't think it exists , hopeful
  3. Billy73
    Billy73 New Member
    9
    Jul 31, 2019
    I thought tremix or somebody made a kit that will work so long as you already have a manual transmission to start with - not trying to change from an automatic.
  4. 70lt1z28
    3,354
    660
    Oct 3, 1999
    Beavercreek, Ohio, USA
  5. Billy73
    Billy73 New Member
    9
    Jul 31, 2019
    Thanks! Not exactly plug and play...
  6. tom3
    tom3 Veteran Member
    11,938
    330
    Aug 1, 1999
    ohio
    Depends some on how your car is built now. The overdrive 5th gear is best with a motor that has some low/mid range torque. A high revving cammed up big carbed engine probably won't match up too well with the Tremec.
  7. Zspoiler
    Zspoiler Veteran Member
    3,229
    260
    May 6, 2012
    Federal Way, Washington
    It also depends on how deep your pockets are.
  8. Green hornet
    Green hornet Veteran Member
    1,685
    278
    Oct 11, 2015
    North Bay, CA
    It usually does lol
  9. G72Zed
    G72Zed Veteran Member
    1,102
    240
    Sep 8, 2015
    In your particular case, I would perhaps give the Richmond S/S 5spd a close look. Very close to the '71-'74 Muncie in dimensions and gives you a lower first gear, and the .77 OD your looking for. Looking at it closely, with a bit of work, you could use mostly all of your existing 4spd Muncie stuff, even the cross member and perhaps the driveshaft.
    I will assume you still have the 3.73 rear and are carbed, if so, and your using a tire of approx. 26.5 inches tall, you will go from 63 mph @ 3000rpm to 69mph @ 2,500 rpm with this trans.
    Absolutely good point, it really depends on rear gearing, trans OD and tire dia. combonation used and a proper tune of course.
    I use an OD 5spd (.77) with a 333 sbc, big cam (262 @ 50) and carb (870) combo and works out great.
  10. grzewnicki
    3,385
    148
    Dec 9, 2009
    Gordon from Jacksonville Fl
    transmission first gear times rear gear should be around 10:1 so TKO500 with 3.27 first gear times a 3.73 rear ratio gives you 12.19, you will go through first gear quickly....don't ask how I know this. I swapped down to 3.42 rear gear set but really should have gone down to 3.23. Do your homework. I was ignorant on this and paid the price having to change rear gears. If I had gone with the TKO600 I would have been right around 10:1. Live and learn.
