Muncie 4-speed or 5-speed Conversion?
Discussion in 'Transmission & Driveline Topics' started by Billy73, Aug 2, 2019.
  1. czizza
    czizza Veteran Member
    1,009
    53
    Jan 8, 2004
    N. Massapequa, NY, USA
    I had a ST10 behind my 409 SBC in my 79Camaro and I broke the transmission 3 times ... I got a TKO500 on Craigslist with a drive shaft for a Cutlass. I got lucky because it was 1000.00 dollars for the stuff.
    The conversion for me was super easy, I had a manual clutch and a 521 bell housing and a 28 spline input shaft. My floor needed a little cutting as my shifter was from the cutlass but the transmission fit in the tunnel with no issues. I got an SST crossmember and the drive shaft from the cutlass had to be shortened. I was out the same day I stated the install.
    http://www.nastyz28.com/threads/tko-500-install-scored-on-craigslist.297319/
  2. G72Zed
    G72Zed Veteran Member
    1,108
    241
    Sep 8, 2015
    To the OP, assuming if your 3.73/26.5 tire, look at the Richmond SS 5spd or TKO600 as they have the same first gear 2.89 vs 2.87 and this would give you a 10.66 overall first gear ratio, and at 6,200 rpm, = 45+ mph in first gear.
    Looking at your stroke of 3.750, the sweet spot for overall first gear ratio would be 10.38 if you come in at 3,750# with driver, so only a little over that with either trans.
    I have driven several Camaro's/Chevelle's with TKO600/3.750 stroked engines , 400sbc/bbc and they both used a 4.10 rear gear (12 bolt), first felt very good and usable in both cars, and the .64 OD was close to perfect for the highway at 70-80 mph. Hope this helps out.
  3. 76z28
    76z28 Veteran Member
    2,024
    47
    Jun 29, 2009
    bakersfield
    If going from auto, the cost of the muncie is not worth it--especially if buying new parts.
    Go 5 or even 6.
    When I priced mine I got the 6 speed within about 400 bucks of the 5 speed. I can't wait to get it in. Not sure when that will be though.
  4. czizza
    1,009
    53
    Jan 8, 2004
    ... That's no fun ... nothing like banging gears and downshifting on turns.
  5. 76z28
    2,024
    47
    Jun 29, 2009
    bakersfield
    Just so much going on...
    May get started soon but we will see.
    I hope to start some time this month
  6. Kricka
    Kricka Veteran Member Lifetime Gold Member
    419
    Sep 26, 2002
    Skellefte. SWEDEN
    I installed a TKO600 (0.64 OD) in 2005. I use my car as a daily driver in the summer and have ~22000 Miles on it.
    It is the best mod i have done so far.
    G72Zed, dave@ztech and tom3 like this.
  7. ZEN357
    ZEN357 Veteran Member
    383
    70
    Feb 12, 2018
  8. Jeep43
    Jeep43 Veteran Member
    1,288
    46
    Mar 30, 1999
    Connecticut
    Has anybody confirmed if the box modifications that some relailers perform for tunnel clearance are required for a 2nd gen? I guess I am asking is has anybody swapped in a box stock TKO into a 2nd gen instead of buying a "kit".
  9. tommy1727
    tommy1727 New Member
    Sep 15, 2013
    Florida
    Silver Sport Transmissions has TKO 5 speed or Magnum 6 speed conversion kits. Check them out. Great kits and customer service. They probably even have YouTube videos of that conversion.
  10. diamondr
    diamondr New Member
    Oct 18, 2001
    whitwell, tennessee, USA
    I have a 1973 Z-28 (bought new) I have a 383 500 horsepower in it. Came from factory with 4 speed pulled the original engine and transmission. Put a TKO 600 behind the 383 works great. Used my 4 speed T- handle from in the 70's. Everyone thinks it is still the 4 speed. I also can run my console. Have the 3.73 original rear runs 1800 to 2000 RPM at 70 mpg in 5th . 5th is .64. Car is a driver not a show queen.
