My 1979 Camaro Z28 Project!
Discussion in 'Project Progress' started by Blu-By-U 79Z, Feb 13, 2009.
  1. Blu-By-U 79Z
    Blu-By-U 79Z Veteran Member Lifetime Gold Member
    5,555
    18
    Feb 11, 2009
    Kentucky
    Thanks man they still need some work but they do look pretty good
  2. 80sz
    80sz Veteran Member
    3,214
    429
    Feb 2, 2014
    Buffalo,n.y.
    Yup,those are going to look primo.fire up the street light
    Blu-By-U 79Z likes this.
  3. sello
    sello New Member
    Jan 27, 2013
    Detroit, MI
    Hello Matt,
    Just FYI, regarding the recurrence of rust on your underbody, I know that you think you removed it all when you stripped the underbody and coated it, but the fact of the matter is that there was likely rust in the crevices where you couldn't strip and definitely in between the sheetmetal panels where they are spot welded together. My understanding is that only a chemical strip/dip, followed by a dip in some anti-corrosive solution or coating is the only real way to remove ALL rust and prevent the rust you can't see from spreading. In addition, your garage/shed does not do anything to keep moisture from the metal of your car. It may keep the rain out, but unless you're parked on a sealed concrete slab, inside a somewhat well sealed enclosure, then your car (anything metal in fact) is still exposed to various amounts of moisture from the air. My garage was so poor in this same manner that my craftsman hand tools started forming rust spots on them, especially on those first warm days of spring when the warm, moist air came into contact with my still ice cold metal tools, and car sheet metal. Anyways, just my two cents. Good luck with the rest of your build, as mentioned by other members, your build thread is an inspiration to many others, including myself, and I don't even have a hot rod anymore!
  4. azuber01
    azuber01 Veteran Member
    297
    Feb 21, 2014
    hinsdale MA
    Did you sand those all down to bare plastic? I'm doing mine now and seems like it will take forever to get all the primer off...
  5. Blu-By-U 79Z
    5,555
    18
    Feb 11, 2009
    Kentucky
    Yes sir. It takes a while but its worth it
    azuber01 likes this.
  6. Blu-By-U 79Z
    5,555
    18
    Feb 11, 2009
    Kentucky
    Merry Christmas my NastyZ28 Family!
    brooksman9 likes this.
  7. Blu-By-U 79Z
    5,555
    18
    Feb 11, 2009
    Kentucky
    Sorry for the long update. So I think my hood search has come to an end. Ended up get a very nice flat hood for free from my buddy. Did the cuts and got the scoop mounted. Still needs some tweaks but at least this hood is rust and crack free.
  8. DB Z28
    DB Z28 Veteran Member
    565
    44
    Nov 30, 2003
    Fond Du Lac
    Matt how do get a hold of you. got something for you that I don,t need.
  9. Blu-By-U 79Z
    5,555
    18
    Feb 11, 2009
    Kentucky
    You can message me or I can send you my phone number
  10. DB Z28
    565
    44
    Nov 30, 2003
    Fond Du Lac
    Send me you phone number if you have a chance
