My 1979 Camaro Z28 Project!
Discussion in 'Project Progress' started by Blu-By-U 79Z, Feb 13, 2009.
  1. Tokyo Torquer3
    Tokyo Torquer3 Veteran Member
    2,187
    Oct 14, 2003
    NJ
    I love that nice big garage!!!!!!!!
    I cant believe you haven't painted that car yet after all these years ;)
    mike
    Blu-By-U 79Z likes this.
  2. Blu-By-U 79Z
    Blu-By-U 79Z Veteran Member Lifetime Gold Member
    5,551
    16
    Feb 11, 2009
    Kentucky
    I know man I kick myself but it's time to make it right lol
  3. Jas0n
    Jas0n Veteran Member Lifetime Gold Member
    1,022
    19
    Apr 27, 2010
    Verona, ITALY
    Hey Matt! Congratulation on everything! Really glad your dad feel better!
    be careful in that garage: you could lost yourself down there! lol!
  4. Blu-By-U 79Z
    5,551
    16
    Feb 11, 2009
    Kentucky
    So this weekend had some decent progress. I had been working on stripping the rear window channel and was having a hard time cleaning the rust pits out.
    So I finally gave in and made a trip to harbour freight for a small 1 liter sand blaster and some aluminum oxide. When I returned home I masked the car up really good and out duck tape around the area I would be blasting. Once I was ready I rolled the car out behind the garage and prepped everything for blasting.
    It turned out pretty good. The blaster worked great for a $25 cheapie. I had a few pin holes to weld up but nothing to major. Sure beat the wire wheel I was using. However it was quite messy but I knew it would be. Definitely wear your protective equipment for sand blasting lol.
    I called it a night and took it easy after I cleaned up my mess and put the car back in the shop.
    Fast forward to Sunday,
    I started out by tack welding the few pin holes that I found in the window channel. Once they were fixed I prepped the car for epoxy primer.
    Last weekend I had built a 35 ft by 10 ft curtain that divides the garage for when I spray primer. I'm still working on I think but I've gotta say for the first trial run it did great.
    It's been a while since I have sprayed epoxy and I put a half part of reducer in it.... lmao shouldn't have done that but it still turned out good. Just alittle more water like that I meant for it to be. It's nice knowing that my rust was gone, holes fixed and epoxy laid down to seal the metal. Now I need to figure out a good way to seal the back side of the channel ( inside quarter panel vent )
    Gotta say I was a nervous wreck doing all of this with the street lites still on the car lol. They will probably be coming back off again soon.
    I did notice today that my POR15 on the rear frame rails had surface rust coming through it. It will be later down the road but I think once the exterior is done then I will have to start redoing that so I can use a better product. It's only
    In spots but I did everything to a T. Oh well nothing I can't handle.
  5. Blu-By-U 79Z
    5,551
    16
    Feb 11, 2009
    Kentucky
    This is the sand blaster I used.
  6. earnhardtgm3
    earnhardtgm3 Veteran Member
    2,878
    33
    Dec 18, 2007
    Camaro Country,GA
    Nice work
  7. Jas0n
    1,022
    19
    Apr 27, 2010
    Verona, ITALY
    Nice! that sand blaster really does its work
  8. woody80z28
    5,570
    57
    Sep 8, 2004
    walton, ny usa
    You're a busy dude! Glad everything is moving in the right direction. Congrats.
    I think your car has been waiting for paint as long as mine! haha
  9. Blu-By-U 79Z
    5,551
    16
    Feb 11, 2009
    Kentucky
    I hear ya man lol. Thanks I'm glad things have started coming together.
  10. 79zBlue
    79zBlue Veteran Member
    259
    Apr 7, 2012
    long island ,NY
    Congrats on the house and wife
