MY 70 Z28 RS COPO ?
Discussion in 'Project Progress' started by WANNARUN, Mar 13, 2018.
  1. Bill Neumiller
    Bill Neumiller New Member
    26
    Aug 25, 2017
    Minnetonka, MN
  2. WANNARUN
    WANNARUN Veteran Member
    311
    96
    Jun 4, 2012
    Long Island NY
  3. WANNARUN
    311
    96
    Jun 4, 2012
    Long Island NY
    92D05531-F1B3-422E-A8BA-C519B9281547.jpeg 70 LT-1
    hubedobeedo likes this.
  4. COPO
    18,423
    1,072
    Jeff, are you planning on getting the smog system back on?
  5. WANNARUN
    311
    96
    Jun 4, 2012
    Long Island NY
    I would like to but the original owner got rid of it. I saw a original one for sale but it was a lot of money. I have also seen reproduction ones. What would you do and where could I buy your suggestion. Thanks
  6. COPO
    18,423
    1,072
    If I didn’t have one then I’d buy a repop cause people want stupid money for a used one that doesn’t turn. My orig pump front bearing seized on me after making a few 6000 rpm hits. I want the pump functional so it’s still keeping the tubes cool with airflow from the pump. Without the pump creating air flow, the smog tubes have an avg temperature of 382F. Avg EX manifold temp of 421F.
    I still haven’t decided whether to dig out the front bearing myself from the sealed epoxy or send the pump out locally for rebuild for about $350. They said they couldn’t guarantee if something may not break. Sending it to the USA is out of the question due to the dollar exchange. So currently the pump and tubes are off the engine.
  7. WANNARUN
    311
    96
    Jun 4, 2012
    Long Island NY
    Thanks for the information.
  8. 70lt1z28
    3,532
    716
    Oct 3, 1999
    Beavercreek, Ohio, USA
    Keep in mind the exhaust temps will be different with a stock cam. The AIR system was designed to create a post combustion process in the exhaust manifolds. Air was pumped in and the heat from the exhaust ignited the unburned raw gas due to the high overlap, long duration stock cam. This would then RAISE the temps in the manifold and the connecting tubes. Any other cam may not behave the same way. You may get higher or even lower exhaust temps with the system disabled and the stock cam.
    hubedobeedo and WANNARUN like this.
  9. COPO
    18,423
    1,072
    Without the pump the pipes are so hot they will give you 1st degree burns. With the pump on the car you can immediately touch the pipes after shutting the engine off. I used to always be in reading the plugs after a run and touching the pipes which were barely warm. Even low HP engines got smog and it all worked the same. https://my1970z28.com/COPO/smog.htm
  10. WANNARUN
    311
    96
    Jun 4, 2012
    Long Island NY
    DCC1A6ED-E86D-4126-AE4D-54BF26B67115.jpeg Original hard to find bright liug nuts.
    hubedobeedo and McCune like this.
