My '73 Pro Street Project
Discussion in 'Project Progress' started by Jodi, May 24, 2019.
  1. Jodi
    Jodi Member
    40
    41
    May 22, 2019
    Master cylinder from a late '70's corvette will be use for hood clearance. Here's a side by side height comparison.
  2. Jodi
    Jodi Member
    40
    41
    May 22, 2019
    Remove the bracket from the factory vacuum booster and cut the pushrod end and set it aside for now.
  3. Jodi
    Jodi Member
    40
    41
    May 22, 2019
    After trial fitting the unit to the car, I found that the factory booster bracket angle is too steep which made the hydroboost pushrod angle too much when hooked up to the brake pedal. Ended up making a bracket with less angle.
  4. Jodi
    Jodi Member
    40
    41
    May 22, 2019
    The hydroboost pushrod is too short and the tip hole is too big for the application. The factory vacuum booster pushrod tip must be use.
    Cut the hydroboost pushrod tip off and discard...thread the remaining part of the pushrod . Also thread the factory vacuum booster pushrod tip that was cut before. Combine the two with a coupling nut, adjust to the proper length and weld.
    20191023_175146[26266].jpg push rod and coupling nut.jpg pushrod and coupling nut assembly.jpg
    Smokey15 likes this.
  5. Jodi
    Jodi Member
    40
    41
    May 22, 2019
    I had to make new brake lines because the old one would not lined up anymore. The proportioning valve was relocated under the master cylinder, old location was under the vacuum booster.
  6. Jodi
    Jodi Member
    40
    41
    May 22, 2019
    I finally got all the fittings! so now I could finish the plumbing on the hydroboost conversion. 20191031_111923[26604].jpg 20191031_111932[26603].jpg 20191031_111953[26606].jpg
  7. Jodi
    Jodi Member
    40
    41
    May 22, 2019
    Decided to use an oil cooler on the conversion (why not), I have this cooler lying around in the garage... don't even remember what it came out off. I cut the end of the inlet/outlet tubing shorter to make it fit better and added a hose retaining bump on the tip using a flaring tool. Also added an extension on the left side bracket for mounting on the radiator cradle. 20191101_095823[26656].jpg 20191031_143718[26607].jpg
    Smokey15, roadrace2 and dave@ztech like this.
  8. Jodi
    Jodi Member
    40
    41
    May 22, 2019
    Here's a numbered diagram of the line connections and where they connect to. Maybe someone doing the same modification or thinking about doing the modification will find it helpful. The Hydroboost unit basically hooks up in series between the power steering pumps pressure line.
    #7 - Hydroboost inlet connects to the pressure outlet of the power steering pump (18mm x 1.5 to -6 AN fitting is required on the hydroboost and a 90 degree 5/8 inverted flare x -6 AN fitting on the Power steering pump. #1 - Hydroboost outlet connects to the pressure outlet of the gear box (16mm x 1.5 to -6 AN fitting is required on the hydroboost and 11/16 inverted flare to -6 AN fitting on the gear box. #3 - Hydro boost return line connects to the tee fitting #2 - Gear box return line connects to the oil cooler inlet. #6 - Return line connects to the oil cooler outlet #5 - Return line from tee fitting to the fluid reservoir. HAPPY WRENCHING!!! . 20191108_151859[27517]_LI.jpg 20191108_152058[27518]_LI.jpg
