My low cost LED Brake lights
Discussion in 'Tips 'n' Tricks Topic' started by Revin, Mar 14, 2019.
  1. Revin
    Revin Veteran Member
    549
    91
    Aug 31, 2016
    Round Rock , TEXAS
    I want to have bright LED tail lights on my 73 Camaro. Problem is I'm cheap. So I came up with this way of making my tail lights on the cheap.
    Disclaimer: The images seen in these pictures are mock-up units not the final product. Please disregard all scratches, broken plastic, chip paint or Dirty Work surface.
    So I bought one of these on eBay for $9.96 just to try.
    It is to thick the way it comes to just lay in bottom of the TL pod with stock Camaro lens.
    So...
    I heated it in my oven @ 200* for a little bit. And was able to remove the lens to get the led board inside.
    Instead of just the pcb laying there, I cut the bottom part to fit the bottom. Reason is the standoff. CON slides right in. Bam. silicone the base to hold it there.
    Super bright. Better in person.
    I plan on getting a socket to mate up with stock harness.(not sure if we use the 1157 bulb, but the idea)
    https://www.ebay.com/itm/4Pcs-1157-...e=STRK:MEBIDX:IT&_trksid=p2060353.m1438.l2649
    There ya go! 1973 Camaro LED TailLights for $10.00.
  2. Twisted_Metal
    27,072
    1,004
    Not too bad. :D
    Personally.... I would move that LED set to your dome light and see if you can get the same setup with Red LEDs.
    Exterior LEDs should always be the same color as the lens.
    It looks too much like a backup light with the really bright white LEDs in the center.
    BradySmmrs likes this.
  3. ULTM8Z
    ULTM8Z Veteran Member
    9,188
    355
    May 19, 2000
    Los Angeles
    Rayden2009 likes this.
  4. djorgensen3
    djorgensen3 Veteran Member
    485
    51
    Oct 15, 2009
    Peoria, Az
    Do you have a link to the LED light you purchased on ebay?
  5. Revin
    549
    91
    Aug 31, 2016
    Round Rock , TEXAS
    Link for the light
    https://www.ebay.com/itm/4-Round-RV-Truck-Trailer-Rubber-Mount-Stop-Turn-Tail-Backup-light-LED-Red-12V/362232974692?ssPageName=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
    Twist
    I agree with the color part. They still "look" red, I may trim the red lens that came with it and try that or maybe even remove the disfuser. They fill up the lens in person. I do have a trick to look into to spread the light output around.
    These are trailer lights. I think the red lens that came with them might be a shade darker red to produce the RED more pronounced Than my old faded stock lens.
    Not to worry! I am still in the R&D stage on these and several other mods....(had to take a break from the bodywork for a bit)
    ULTM8Z - I like that with the halo! are the halo the turn signals? Lots of work compared to mine, but worth it!
    I looked at several others on line and Hella has nice ones:D but way too expensive for my wallet.
    I could not tell if the center were white(backup) so didn't get these. but the style I wanted to do is like that from Hella. Like yours!
    https://www.ebay.com/itm/2-RED-LED-4-Round-Truck-Trailer-Stop-Turn-Tail-Flange-Mount-Lite-W-CLEAR-LENS/271629076775?ssPageName=STRK:MEBIDX:IT&_trksid=p2060353.m1438.l2649
  6. ULTM8Z
    9,188
    355
    May 19, 2000
    Los Angeles
    The halos are the tail lights. Stop and turn signals are the center sections.
    I actually updated them since the time I did that write up, using some 4" COB Halo rings...
    mrluckies and 80sz like this.
  7. Revin
    549
    91
    Aug 31, 2016
    Round Rock , TEXAS
    dam I need to go back to drawing board! I like that very much!
  8. 75Maro
    75Maro Veteran Member
    435
    18
    Mar 31, 2008
    Dallas,Tx
  9. 75Maro
    435
    18
    Mar 31, 2008
    Dallas,Tx
    NEED AN UPDATED WRITE UP WITH PN'S! THIS IS SICK!
  10. NorCal_71
    NorCal_71 Veteran Member
    378
    Jul 7, 2008
    Santa Rosa, CA
    mrluckies likes this.
