My low cost LED Brake lights
Discussion in 'Tips 'n' Tricks Topic' started by Revin, Mar 14, 2019.
  1. mrfleet12
    mrfleet12 Veteran Member
    355
    111
    Aug 8, 2014
    West of Chicago IL
    When you're installing these low cost LED setups, are you adding any resistors, relays or anything like that to run these? My buddy gave me a set of LEDs that have yellow on the top and white on the bottom, they're 8" long by about 1 " tall. They come with mounting brackets that would fit them inside the front turn signal on my non RS car.. Wondering if there's anything I'd need to do to use these as driving lights and turn signals? Maybe a different flasher?
    Thanks
  2. Twisted_Metal
    27,157
    1,046
    You will need to use an electronic flasher with external LED signal lights.
    (LED dash indicators alone don’t require a different flasher.)
    Electronic flashers function on a timer circuit rather than resistance/heat to trigger the on/off cycle.
  3. mrfleet12
    355
    111
    Aug 8, 2014
    West of Chicago IL
    That's twisted.
  4. Revin
    Revin Veteran Member
    554
    91
    Aug 31, 2016
    Round Rock , TEXAS
    I agree with twisted
    mrfleet12 likes this.
  5. Rayden2009
    Rayden2009 Veteran Member Gold Member
    111
    14
    May 12, 2016
    Calgary AB
  6. ULTM8Z
    ULTM8Z Veteran Member
    9,216
    368
    May 19, 2000
    Los Angeles
    thanks!!
  7. 75Maro
    75Maro Veteran Member
    435
    18
    Mar 31, 2008
    Dallas,Tx
