My LQ4 Swap
Discussion in 'High Tech Retrofits' started by TheMeat, Dec 21, 2012.
  1. TheMeat
    TheMeat Veteran Member
    970
    Feb 9, 2007
    Ol' Miss.
    Here are a few pictures showing the differences between the 2001 LQ4 rods and a set of 2006 LS2 rods.
    LS2 ROD
    LQ4 ROD
    LS2 ROD
    LQ4 ROD
    LQ4 ROD on left/LS2 ROD on right
  2. TheMeat
    970
    Feb 9, 2007
    Ol' Miss.
    LS2
    LQ4
  3. TheMeat
    970
    Feb 9, 2007
    Ol' Miss.
    I plan on using the LS2 Rods/crank/pistons after I swap the 54X reluctor wheel for the 24X so it will work with the PCM I have.
    The cranks are identical otherwise and share the same part number. The rod and crank bearings in the high mileage LQ4 (195,000) looked awesome. I would have replaced the cam bearings, rings, lifters, cam, and chain as they seemed to be the worn items.
  4. camarochevy1970
    camarochevy1970 Veteran Member
    7,794
    57
    Jan 23, 2003
    Pittsburgh, PA
    swapping that reluctor wheel isn't super easy, so take your time and get it right. Another option is the Lingenfelter controller to make a 58x wheel work with a 24x pcm
  5. TheMeat
    970
    Feb 9, 2007
    Ol' Miss.
    That's what I read. I found the Goodson tool online for ~$200 though and a replacement wheel is $20 from GM. Late model engine in Texas offers a billet 24x reluctor but they want $199 for it!!:eek:
    Anyhow, I dropped my block and crank off at a trusted local machine shop who does many LS builds. The owner looked over my parts and was in agreement that the bores should clean up with just a hone and my "new to me" LS2 pistons would work fine in it.
    I am having the block jet cleaned, honed, decked, new cam bearings installed and a 24X reluctor wheel installed. Should be done no later Monday.
  6. TheMeat
    970
    Feb 9, 2007
    Ol' Miss.
    Cleaned up all of my pistons....
    Also, got this solvent from Harbor Freight so I can get everything pretty clean and painted prior to install. Solvent was more $$$ than the tank!
  7. TheMeat
    970
    Feb 9, 2007
    Ol' Miss.
    Hopefully I can start cleaning the engine bay too and touching up some areas that need attention..
  8. Leonards78LT
    Leonards78LT Veteran Member Lifetime Gold Member
    1,031
    Jan 21, 2001
    Central Oklahoma
    Who in the heck needs a billet reluctor? It's not like you can see it. Oooh, I got as billet reluctor.:rolleyes:
    The local machine shop I used has been in business since the 60's and I believe I was the first LS block they ever did. They did not even have the reluctor install tool, and yes, I purchased the one from Goodson and installed a new wheel myself. I just had them do the machine work to bore the block and centerline bore the mains to be sure they were true. Took great pride in assembling the motor myself.
    Good luck on your project. :smokin:
  9. 71RS/SS396
    71RS/SS396 Veteran Member
    2,627
    30
    Aug 26, 2008
    Wake Forest NC
    The stock reluctor wheels like to explode with a big shot of nitrous or on high powered turbo engines.
  10. TheMeat
    970
    Feb 9, 2007
    Ol' Miss.
    This^. I decided that the extra money spent on a reluctor could be better used elsewhere in my particular build.
    There is quite a bit of difference between the 24X reluctor and the 58X reluctor just upon visual inspection in regards to the build quality.
    I will take a picture of each for comparison when I get my other crank back.
