My ly6 build
Discussion in 'High Tech Retrofits' started by RICARDO1969, Nov 16, 2010.
  1. RICARDO1969
    RICARDO1969 Veteran Member Lifetime Gold Member
    2,086
    Oct 14, 2007
    Waukesha WI
    So i thought i would make a new thread documenting my ly6 build.
    I bought this for around 2 grand give or take a dollar or two :) motor came from a 2008 GMC sierra 2500 HD truck. 21,000 MILES.
    Went with brp's install kit came with mounts crosmember oil pan and all fasteners the fit is very nice and the parts look great.
    I have decided i want to go carberated i hate dealing with a ton of wires plus
    i love the look of a carbed motor.
    I started cleaning her up sprayed a couple of coats of gloss black. i am also keeping the VVT i will be using the msd 6012 box to fire the coils.
    I chose the vic jr intake will be running a Barry grant 750 carb.
    and turn one ps pump set up.
  2. RICARDO1969
    2,086
    Oct 14, 2007
    Waukesha WI
    also went with a 06 zo6 clutch it was a new take out and the price was rite.
    I will be using my original numbers matching (RPO CODE M21) IRON CASE & IRON MID PLATE CLOSE RATIO SUPER T-10 4 SPEED :)
    I had the trans set up to match the rear gear "3:73'S"
    BIG THANKS TO DAVE'S 4 SPEEDS HE DID A AWESOME JOB!
    I will bell-housing lakewood's 150050 belhousing
    http://www.davids4speeds.com/
    Also using the f-body drive system after some trial and error fitting parts i finally got it rite i used a f-body water pump with 1.5 spacers to clear the vvt i also spaced out the power steering and alternator 3/4's of an inch away from the motor, i also used a vette tensioner at first i used the f-body balancer that was a no go since it did not line up so i went back to the truck balancer it came with and it was a perfect match, also want to mention that i had no problems with the pitman anr clearence its all good :)
    I will be updating as cash deems necessary lol.
  3. RICARDO1969
    2,086
    Oct 14, 2007
    Waukesha WI
  4. frankz
    frankz Veteran Member
    2,090
    13
    Aug 24, 2009
    Illinois
    Ricardo,Gotta say that looks sweet......Should I be concerned if our paths cross in the state line area?? LOL Cuz it looks like it will be a runner!
  5. RICARDO1969
    2,086
    Oct 14, 2007
    Waukesha WI
    lol ya never know :)
  6. jthomas
    1,554
    81
    Dec 5, 2007
    NorthCentral PA
    Looks great!
  7. Todd80Z28
    11,569
    245
    Jun 11, 2002
    Northern VA
    Nice fit!
    Weren't some other folks here having trouble with that type of alternator mount?
  8. QUAKE_WARS
    QUAKE_WARS Veteran Member
    2,021
    149
    Dec 19, 2008
    Nice
  9. Aceshigh
    26,757
    Apr 9, 2001
    Boondocks
    Sweet.
    I'd like to see a build sheet with part #'s and prices for a carb'd setup.
    I don't think anyone here has done a full list like that yet to compare. :bowtie:
    Keeping the fuel injection runs you probably ~$550 for a tank & pump, plus Speartech mods $800.
    So ~$1350 to keep it. So I'm curious what it cost to compare to lose the EFI.
    Depends on which alternator it is.
    That's the same mount as the GTO and F-body, but the GTO alternator I heard is bigger.
    I guess it's the luck of the draw with your motor mounts too.
  10. JJFarmer
    JJFarmer Veteran Member
    2,447
    Jun 28, 2002
    Lenoir City, TN
    Another fine thread to follow!!! Looks good in there too
