My pitman arm is hitting the alternator...suggestions?
Discussion in 'High Tech Retrofits' started by mikes70, Jun 11, 2013.
  1. mikes70
    mikes70 Veteran Member
    202
    Apr 24, 2008
    livermore, ca
    Hey, have any of you in doing an LS swap have the pitman arm hit the lower mount alternator? Gen 2 1970 Camaro, 04' GTO LS1
    Thinking of finding a dropped pitman, and i might be able to go up an inch with the engine, the tranny is a T56 without the tunnel cut...might have too, ewe...
    Any thoughts, thanx, Mike
  2. Protour-Camaro
    Protour-Camaro Veteran Member
    2,111
    Feb 16, 2012
    California
    Mike, Very common problem for power steering cars. You need the TransAm pitman arm with a drop. I had the same issue, swapped the arm and plenty of clearance.
    http://www.ebay.com/itm/70-81-FIREBIRD-TRANS-AM-TA-FORMULA-STEERING-BOX-PITMAN-PITTMAN-ARM-7809576-/390589035593?pt=Motors_Car_Truck_Parts_Accessories&fits=Year%3A1981|Model%3AFirebird&hash=item5af0ebb449&vxp=mtr
  3. mikes70
    202
    Apr 24, 2008
    livermore, ca
    Sweet, thanks for the quick replay. Will do...
  4. orkin
    orkin Veteran Member
    257
    Apr 27, 2011
    Texas
    Do you need the matching idler arm?
  5. 2ndGenCrazy
    2ndGenCrazy Veteran Member
    723
    33
    Aug 18, 2011
    Upstate New York
    Are you using original pedastal, or newer clam shell mount?
  6. ryeguy2006a
    ryeguy2006a Veteran Member
    157
    Sep 29, 2009
    Upstate, NY
    Like what was said above, use the Trans Am with a drop pitman. And to answer the question, no you don't need to change the idler arm either. I have a straight idler and Trans Am drop pitman arm with no problems.
  7. Protour-Camaro
    2,111
    Feb 16, 2012
    California
    I didn't swap my idler arm either. I don't even think there even is one. I searched and searched...they all have the same idler.
  8. mikes70
    202
    Apr 24, 2008
    livermore, ca
    Thanx for the replies, i am going to order one from Summit as we type...
  9. Protour-Camaro
    2,111
    Feb 16, 2012
    California
    Be cautious ordering new....The part I listed is rare and I don't think you can get a new one.
  10. Aceshigh
    26,757
    Apr 9, 2001
    Boondocks
    I have the same motor in mine.
    Unfortunately back in 2006 I didn't know about the dropped pitman arm option.
    I relocated my alternator to the top right side of the motor with a $500 alternator kit.
    No KY......
