My pitman arm is hitting the alternator...suggestions?
Discussion in 'High Tech Retrofits' started by mikes70, Jun 11, 2013.
  1. Protour-Camaro
    Protour-Camaro Veteran Member
    2,111
    Feb 16, 2012
    California
    It's still produced...Summit Racing has the Moog for $99. You can find off brand names on Ebay for $70. I'm sure Rock-Auto.com has them too.
    "Centerlink" or "draglink" will yield the results. The one thing I wouldn't do is buy a used one...
    As for the tie-rods....Yes the part #s seem to be different, but why?
  2. Underliner6
    Underliner6 Member
    35
    Jan 2, 2015
    Sedona, AZ
    Reviving and old thread. I’m looking for a part # on the bent “1978” pitman arm for my LS swap. When I search eBay, I find a lot of different options I am not certain will work.
    I will also be using the DS883 centerlink.
  3. badazz81z28
    17,358
    598
    Alabama
  4. Underliner6
    Underliner6 Member
    35
    Jan 2, 2015
    Sedona, AZ
  5. 1971CamaroGuy
    3,771
    172
    Oct 31, 2004
    It's not exactly the same...my advice: You better jump on that junk one since it's the last one left. These don't come up very often and when I sold mine it was def more than $49.
    Pitman arms are one of those parts that hold up well, clean it up and spray some cast iron paint on it and your good to go.
  6. Underliner6
    Underliner6 Member
    35
    Jan 2, 2015
    Sedona, AZ
    I’ll take your advice. I sucked it up and ordered it. Now I just need the Moog DS883 center link and tie rods and I’ll be good to go.
  7. Underliner6
    Underliner6 Member
    35
    Jan 2, 2015
    Sedona, AZ
    Few more verifying questions as my head is spinning from all I have read on this topic. I am getting ES2001L/ ES2002L Moog inner tie rods.
    I have read that the trans am and Camaro outer tie rods are the same but Moog.com is saying I need ES427R outer tie rods that other sites are saying are not compatible. Anybody have insight on the outer tie rods?
    Thanks for spoon feeding me. Lmao
  8. badazz81z28
    17,358
    598
    Alabama
    I wasn’t even tracking there was a reproduction out there. I bet any repro is the flat one.
    As for steering linkage, you need the. Matching drag link to accommodate the drop. I just ended up buying a complete pro-forged kit.
  9. 75Maro
    75Maro Veteran Member
    439
    28
    Mar 31, 2008
    Dallas,Tx
    This may not be accurate, I swapped the pitman arm only and kept the original linkage. Works fine.
  10. Underliner6
    Underliner6 Member
    35
    Jan 2, 2015
    Sedona, AZ
    I suppose I’ll just get the drag link and see if the stock Camaro inner/ outer tie rods work. If they don’t, I can have them delivered within a few days from Amazon.
