My pitman arm is hitting the alternator...suggestions?
Discussion in 'High Tech Retrofits' started by mikes70, Jun 11, 2013.
  1. dave@ztech
    3,627
    761
    Mar 27, 2016
    NY
    I also agree with BA, that having the parts out of horizontal alignment, could be affecting them in some way, removing some of there movement capabilities , and now that you see it , you know it will be on your mind every time to drive the car !! HAA HA
  2. badazz81z28
    17,358
    598
    Alabama
    I’m pretty confident the zerk fitting becomes an issue. Under a hard bump or normal driving or with a lowered car that will hit the tie rod. The TA inner tie rods are more curved for the clearance. It’s been a while, but there were a few reasons I got the whole set-up
  3. 75Maro
    75Maro Veteran Member
    439
    28
    Mar 31, 2008
    Dallas,Tx
    Good access to all grease fittings
