Need A Diagnosis for Overheating
Discussion in 'The BS Topic' started by GoldenOne7710, Nov 10, 2019.
  1. GoldenOne7710
    4,825
    415
    Jun 23, 2004
    Athens, GA
    My brother's 2013 Silverado with 5.3L. About 160K miles on it. Said it started running hot today while he was driving. Said he pulled over...but didn't shut off engine, and the temperature slowly fell back to 210 (normal).
    So...only runs hot while engine is under a load. Told him to bring it to me since he wasn't far away. Cooling fans kick on/off as they normally would. Thermostat seems to be opening and closing normally. Another symptom...coolant level is low and no signs of external leaks.
    I don't have a pressure tester and no access to one until about Tuesday. I go ahead and remove the spark plugs to see if anything stands out. Sure enough, 7 out of 8 look to be burning perfectly normal. This one, however...cylinder #1...
    Something has this one cooking. Is this a tale tale sign of coolant getting into this cylinder? Or is simply from overheating?
    I should add...he had these spark plugs changed about 60K miles ago. He said 3 months later, the truck had a misfire...bank 1, cylinder 1...this same cylinder. He changed just the plug and the misfire went away. It wasn't misfiring today...but it looks like it was just a matter of time.
  2. bfmgoalie
    bfmgoalie Veteran Member
    1,968
    240
    Jun 14, 2008
    Gansevoort, New York
    Many years ago (I mean many:rolleyes::rolleyes:) I owned a '70 GTO with a 455. Same thing happened. Problem? Head gasket.
  3. Fbird
    4,039
    647
    Feb 12, 2011
    atlanta, ga
    not familiar with said motor....but #1 is getting a little EXTRA something in there to burn. If he was only driving (not towing) and it got "hot"...there is good reason to be concerned ... again each family of engines have their own UNIQUE problems. Sure one of the guys familiar with the 5.3 will chime in.
  4. Mike N
    2,771
    539
    Jan 13, 2002
    Spencerport, NY.
    Looks more like oil burning than coolant. If that hole was burning water, I'd expect to see the plug looking like it was steam cleaned.
    Running hot under a load sounds like a plugged radiator to me.
    John Wright likes this.
  5. czizza
    czizza Veteran Member
    1,026
    68
    Jan 8, 2004
    N. Massapequa, NY, USA
    Since you said under load, a bad water pump blades are cavitating the water
  6. Knuckle Dragger
    14,851
    1,359
    Nov 2, 2002
    Waddell AZ
    I have yet to see one of our 5.3 Tahoes blow a head gasket. I have seen both water pump failures and radiator overheats. The steam port seals are sneaky and leak without much evidence. The radiator tanks crack in front and hide leaks as well as the heater hoses at the heater core. If you're still using Dexcool it tends to leave a trail but on the hoses it's usually only where you can see it from under the vehicle. The reservoir tanks crack and leak down the fender wells, again not real obvious.
    I agree with Mike coolant should leave the plug clean.
  7. GoldenOne7710
    4,825
    415
    Jun 23, 2004
    Athens, GA
    I disconnected the lower radiator hose at the thermostat housing and also the upper radiator hose at the radiator. Flushed the radiator with plain water from the upper inlet and watched it come out the lower hose. After the "pink" disappeared, it ran clear. Nothing I observed caused me to believe there was any restriction of flow in the radiator.
    Removed the thermostat and flushed water through the engine. Again, once the pink was gone, it ran clear. Zero signs of sludge, crystallization or solidification...not in the engine, radiator, overflow tank or hoses. Buttoned it up with no thermostat and started it up. The coolant flows like a champ. Let it cool enough and installed new thermostat, topped off and bled system. 3 miles up the road, shot up to 260 again. Pull over to let idle...temp drops back to normal.
    I see no external leaks anywhere. Even crawled under it while it was running...nada.
  8. gramps
    gramps Veteran Member
    977
    342
    Jul 5, 2009
    mankato, mn
    Don’t see it being a head gasket issue. Those are so rare on an ls (at least one that’s untouched from the factory) that id bet on magic pixie unicorn dust first- it’s obviously burning oil looking at the plug and those AFM/DOD (cyl shutdown) models have oil burning issues on 1-3-4-8.
    Have you verified that it Is getting those temps and that you don’t have a faulty sender or gauge?
  9. bourbon_scotch
    2,385
    133
    Jan 10, 2003
    USA
    before you said anything about spark plugs i would have guessed the tranny was heating it up
  10. Fbird
    4,039
    647
    Feb 12, 2011
    atlanta, ga
    1 more check....with upper hose off at radiator....run truck...point hose AWAY FROM YOU...(no darwin moments here)...once thermostat opens...water should GUSH out of hose. (not sure if you have a typical radiator cap so you can see inside the rad)....rev it up....should gush MORE!!!
    Had similar on a lil toyo v6 yrs ago....dam impellar broke OFF the water pump...would idle all day no problem ...soon as i would put some rpm in it....would get hot....tell tell sign was the fan didn't come on...BECAUSE the water never got circulated. and thats where the FAN temp switch was ...in the rad.
