Need a header recommendation
Discussion in 'High Performance Modifications' started by 2000z, Aug 24, 2019.
  1. 2000z
    2000z Member
    58
    Sep 18, 2005
    tulsa, ok
    Had a starter go out on me today and my current passenger side header had to come off to get to the outside starter bolt. Needless to say these aren't going back on. My car is a manual transmission with zbar linkage so I need a set that fits good with a zbar and obviously a starter lol. I'd rather not spend a ton of money, but I'd like a decent set. What do you folks recommend?
  2. 1980RS
    1980RS Veteran Member
    3,117
    488
    Jun 17, 2006
    MN
    On my street cars with a SBC I have always used the cyclone 1 5/8 headers, I have run as quick as 11.56 with them and when I went to the high buck hookers I picked up less than a tenth and 1-2 mph. The hookers for me are not worth what they charge. If I had to buy new I would get hedman this time.
  3. Lowend
    14,917
    426
    Mar 25, 1999
    San Jose, CA, USA
    77 cruiser likes this.
  4. grzewnicki
    3,227
    86
    Dec 9, 2009
    Gordon from Jacksonville Fl
    Quite a few posts on here recommending Hedman (I have set), never have I heard anyone say they have had any problems with Hedman. I went with the ceramic coated and they still look good after 6 years.
  5. Zspoiler
    Zspoiler Veteran Member
    3,150
    239
    May 6, 2012
    Federal Way, Washington
    What exactly are you going to with the car? There are such brands such as Hooker .Headman , I have a supercharged car.And I run Doug Thorley long tube headers that have been "cermachrome" I also run and Moroso starter shield with a tilton mini starters for years on both my cars .With no issues,.
  6. G72Zed
    G72Zed Veteran Member
    987
    214
    Sep 8, 2015
    I would look at the Hooker Super Comps # 2117. They would support your future power levels and they fit with the Zbar and you can get and service the starter, also great with angle plugs.
    I have a pair that I "shortened" due to engine set-down, and a 8 qt custom RR pan that makes the bolt access a little tighter, but I can service my starter and it's a 2 piece unit that uses the longer outside bolt, most are short outside bolt I think, so those should do the trick, although the headers are a little more expensive, these are the best I have used so far. Had the car on the hoist for inspection, pic are worth allot sometimes.
  7. tjmugg
    tjmugg New Member
    27
    Aug 4, 2016
    New England
    I am thinking of swapping my stock exhaust manifolds out and installing Hedman ceramic headers. The heads are stock on my 355 with a mild cam. Do you know if they match up well with the exhaust ports on the stock heads?
  8. Lowend
    14,917
    426
    Mar 25, 1999
    San Jose, CA, USA
    Yes, keep in mind the stock mass-produced manifolds don't match up all that well.
