Need a (pref) 4 or 5 Speed Manual Transmission for a '73 Camaro.
Discussion in 'Transmission & Driveline Topics' started by Ted Jaramillo, Oct 20, 2019.
  1. Ted Jaramillo
    Ted Jaramillo New Member
    Oct 20, 2019
    Hey guys
    Being in South America I have few (if Any) Junkyard Options to replace an adapted Toyot Transmission on my latest Project.
    I'd like to know what to look for (Common Gearboxes I may be able to find) OR New AFtermarket Options available in the States, without going to a Tremec as my budget wont allow it.
    Thanks guys,
    TJ
  2. badazz81z28
    16,566
    430
    Las Vegas, NV
    OEM Borg Warner T-10 will be a great option and shouldn’t be too costly. I would avoid the OEM T5
  3. Ted Jaramillo
    Oct 20, 2019
    Awesome. its an OD Gearbox then? (I wasnt sure)
    And where would you buy one?
    Tks!
  4. big gear head
    big gear head Veteran Member
    6,170
    78
    Jul 30, 2001
    Central City, Ky.
    T10 is a 4 speed with no overdrive. If you get the one with the 3.42 first gear then you could run a 3.08 rear end and still be able to take off without slipping the clutch. The T5 isn't very strong and wouldn't be able to handle a lot of power.
  5. badazz81z28
    16,566
    430
    Las Vegas, NV
    Yeah. No 4 speed that I know of is OD. What is the budget?
  6. Ted Jaramillo
    Oct 20, 2019
    Was hoping to get this done for well under $2k
  7. Lowend
    14,948
    434
    Mar 25, 1999
    San Jose, CA, USA
    I don't know what was imported to South Africa, but the T56 from the 4th generation Camaro's can be adapted. The 6th gear is amazing on the highway
  8. C4Racer
    C4Racer Veteran Member
    641
    109
    Oct 26, 2018
    You would find a used T56 the same way you would find a used T10 - in the US it would be at a junkyard or on craigslist from a person selling one. What is available where you are - we have no way of knowing.
    T10 should be what's in most 2nd gen Camaro's or mid to late 70s Corvettes with a 4 speed.
    T56 came in '93+ Camaro's - 6 speed with a .5 OD 6th gear
    You could also adapt a ZF from a '88-'96 Corvette especially if you can pick up the entire assembly - bellhousing, clutch, flywheel, slave cylinder. You would need a different flywheel but everything else should bolt up to a gen1 SBC.
    I wouldn't bother with a T5 from a 3rd gen camaro - not strong enough for a good running 350.
    Won't find anything new for that budget - even in a 4 speed. $3K and up for just the trans, then you need to source bellhousing, clutch, flywheel. If you can get the whole package in a used set-up that would be the best way to keep within your budget. Easily doable with a T10 or T56.
  9. C4Racer
    641
    109
    Oct 26, 2018
    South America, not South Africa. But didn't mention what country - kind of a big continent - it's like saying you're in Europe.
  10. biker
    biker Veteran Member
    808
    60
    Dec 7, 2014
    New Liskeard Ontario Canada
    Europe is not a big continent.
