Need EFI fuel tank recommendations
Discussion in 'High Tech Retrofits' started by 72BIGBLOCK, Mar 27, 2018.
  1. 72BIGBLOCK
    72BIGBLOCK Veteran Member
    2,368
    80
    Feb 2, 2008
    SF
    A769FCA4-5F60-4F9E-8155-B2A5C4469B30.jpeg hi everyone
    I have a tanks inc fuel tank and pump on my 69 camaro but I can smell fuel so after I had an issue with the fuel pump I realized I had a small tiny pin hole leak on the nose from when they welded the piece on, it’s very small and after a while you can see the fuel soak through so I will not consider tanks Inc at all. At this point I rather pay more for a better quality tank
    What other efi tanks do you recommend?
    I’d like to stay in the 400-600 range for the pump and the tank.
    Car has an ls 1 and a t56 not that it matters but yeah
    Thanks in advance
  2. Goat
    1,905
    43
    Jun 7, 2001
    moncure, NC
    I have a "Ricks Tanks" unit. Extremely nice tank and helpful sales guy, but unfortunately, out of the price range you mentioned...
    I'm sure someone else will chime in with something more in your range. I did a lot of research before buying mine and I seem to remember some other decent ones out there for less $$.
  3. John Wright
    14,663
    202
    Aug 9, 2002
    Rustburg, Va
    You could have a radiator shop fix the hole and add a Walbro 450. They have the means to boil and clean the tank enough to weld up the pinhole you found. Just a thought. Also use teflon lined fuel hose anywhere you need a flexible hose to eliminate the fuel smell.
  4. reedld
    reedld Veteran Member
    268
    Aug 9, 2007
    Painted Post NY
  5. Goat
    1,905
    43
    Jun 7, 2001
    moncure, NC
    +2
  6. badazz81z28
    16,572
    434
    Las Vegas, NV
    I suggest a Vaporworks/Ricks Hot Rod Tank. They have lower cost stamped tanks these days. Running a LS3 module is way nicer then the generic Walbro. I also have a LS3 module with the pressure regulator mod done. It’s like a $500 pump from Ricks. I’m selling it because I upgraded to the ZL1 pump.
    https://rickstanks.com/
  7. patpkk
    patpkk Veteran Member
    185
    Jul 21, 2008
    I used Rick's stainless as well.
    It is pricy, but a good piece.
    I got mine with front corners with 45 degree box in to make room for tail pipes.
    It worked good to get three inch exhaust out to the rear of the car.
  8. badazz81z28
    16,572
    434
    Las Vegas, NV
    You know the tanks really are not that much money. It’s the modified fuel module and level sender. A stamped tank is the way to go and you can even buy it on Summit Racing.
  9. CorkyE
    10,265
    430
