Need help for spindle
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by mumu74, Dec 26, 2018.
  1. mumu74
    mumu74 Veteran Member
    139
    Jul 31, 2011
    canada
    Bought wilwood 6 piston calipers and disc.like to know which spindle can I use on my 74 camaro.i already bought spindle but the ridetech send me the wrong one from 69 camaro.so I like to know which spindle is good for my car.
    Thanks
  2. 79T/Aman
    79T/Aman Veteran Member NastyZ28 Sponsor NazstyZ28 Sponsor Lifetime Gold Member
    2,344
    70
    Oct 7, 2004
    Dickson TN.
    your stock ones, curious what makes you think you need different spindles?
  3. 72BIGBLOCK
    72BIGBLOCK Veteran Member
    2,307
    75
    Feb 2, 2008
    SF
    The stock spindle will work with a 6 piston aftermarket caliper and rotor ?
  4. mumu74
    139
    Jul 31, 2011
    canada
    I have noticed stock spindle upper ball joint hole is little smaller then the upper ridetech ball joint.i am confused do i have to make the hole bigger on stock spindle to make sit the ridetech upper arm ball joint in it?I have ridetech complete suspension with coilover. Like to know will it make difference if I get 2 inch drop Spindle?
  5. mumu74
    139
    Jul 31, 2011
    canada
    This is the one.
  6. mumu74
    139
    Jul 31, 2011
    canada
    Actually I ordered complete ridetech suspension kit with wilwood brake kit and it came with tall spindle when I tried to install the bracket of brake caliper it was not matching the holes.so I checked they send me the wrong spindle from 69.now I am scared they won't send anything wrong again cuz they told me to research which spindle is is good for my 74 ridetech suspension .
  7. mumu74
    139
    Jul 31, 2011
    canada
    Compare with the stock the stock ball joint is thinner.
  8. 79T/Aman
    2,344
    70
    Oct 7, 2004
    Dickson TN.
    sorry unfortunately it's RT's mess I don't know what they did.
  9. C4Racer
    C4Racer Veteran Member
    465
    60
    Oct 26, 2018
    RT only makes one spindle for 67-81 Camaros. It’s a tall spindle but the shaft size and caliper holes are same as a stock short spindle from a 67-69 Camaro.
    But regardless the kit is a compete suspension it should all work together.
  10. C4Racer
    465
    60
    Oct 26, 2018
    Why are you using the stock upper arm and ball joint ? Use the parts in the RT kit.
