need help wiring up a "switched power" distribution
Discussion in 'Electrical Systems' started by buildinmy73, Jan 1, 2016.
  1. buildinmy73
    buildinmy73 Veteran Member
    1,083
    10
    Oct 20, 2007
    Bernardston, MA
    I wanted to install a buss bar to pull switched power off of but needed some help.
    i was thinking ..
    run purple ignition switch wire to a relay to then power up a switched power buss bar .
    is this the right way to do this ?
  2. buildinmy73
    1,083
    10
    Oct 20, 2007
    Bernardston, MA
    Ttt
  3. muscl car
    21,635
    611
    Jul 8, 2001
    High Desert of Hesperia Calif
    If for a race car I would suggest going with .... www.leashelectronics.com
    I'm using some of their products to wire up my street/ strip Camaro
  4. buildinmy73
    1,083
    10
    Oct 20, 2007
    Bernardston, MA
    Thanks muscle car . I already have a block but needed more info on how to wire it .
    i think the way i described above is correct but wanted more input
  5. buildinmy73
    1,083
    10
    Oct 20, 2007
    Bernardston, MA
    nobody else has wanted to do this? have all their switched power wires be nice and neat and go to a common busbar? the other question i had was to power it up with an ACC wire Or IGN wire ?
  6. BonzoHansen
    19,351
    724
    Jun 1, 2005
    Scott from Hamilton, NJ
    purple lead is start
    pink lead (on hei cars) is IGN
    start is probably not what you want.
  7. JONESYFXR
    JONESYFXR Veteran Member
    2,177
    Oct 10, 2009
    BUFFALO, NY
    Get a high current constant duty relay and use that to power the bus bar.
  8. mjoc
    mjoc Veteran Member
    3,511
    Apr 29, 2003
    Sherman Oaks, Ca
  9. buildinmy73
    1,083
    10
    Oct 20, 2007
    Bernardston, MA
    Thanks for the replys. I plan on using a relay . but... my question is whether to use ACC or IGN for the relay activation i was afraid if i use IGN that the items would cycle on and off as car cranks? does this make sense? or would it be better to use the ACC
  10. orkin
    orkin Veteran Member
    256
    Apr 27, 2011
    Texas
    On run ING and ACC have power. During cranking only ING has power.
