need help with 15X10s please non mechanic
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by 1979camz28, Jun 7, 2011.
  1. 1979camz28
    1979camz28 Veteran Member
    109
    Aug 20, 2010
    rockland county, ny
    i recently bought from summit the cragar 15x10 soft 8s..my problem i am having is the 275\60\15 will not fit the will completely hit fender..yes im into the old school look with 4 inch bs..now i was just gonna run 255s but the suggested rim size is 9in..what can i do..how do i still get away with using the 15x10s ..koni suspension and new stockk leafs..thanks alot
  2. rtanner
    rtanner Veteran Member
    177
    May 29, 2010
    fairfeild texas
    air shocks! thats how it was done, old school.
  3. 1979camz28
    109
    Aug 20, 2010
    rockland county, ny
    lol well i was born in the 80's so didnt know that ..there has to be something else i can do..charge me big bucks to return thats if they let me
  4. camaro1980b
    camaro1980b Veteran Member
    243
    May 17, 2011
    bridgeport ct
    will u can raise the car or do what off road trucks do and cut the fender
  5. K5JMP
    10,216
    9
    Oct 19, 2006
    MORTUORUM VENATOR - Z.R.T.
    air-shocks, or 9 inch wheels with a 4.5" BS... or road racing wheel well flares..
    or you could mini-tub and narrow the rear..lol:innocent:
    sorry, but you're pretty much hosed for the combo you have.
    I run 275/40/17's on a 9 inch/4.5 BS wheel and it's pretty tight for me too.:cool:
  6. muscl car
    21,955
    795
    Jul 8, 2001
    High Desert of Hesperia Calif
    15x10 ansen sprints with 3-1/8th bs mounted on a set of mickey thompson indy profile N50-15's which are 28.50 x 12.75-15's .i had to use air shocks but only 25 psi in them
  7. 1979camz28
    109
    Aug 20, 2010
    rockland county, ny
    ok it looks like im screwed..i think im gonna try to return and get 9inch or 8inch with 4inch bs..i dont wanna go messing with tubing flaring or adding air shocks..never had so much headaches with my car ever..
  8. K5JMP
    10,216
    9
    Oct 19, 2006
    air shocks are the easy way out man...
  9. 1979camz28
    109
    Aug 20, 2010
    rockland county, ny
    k5jmp..ok bro so do u have a link to some air shocks that arent going to break the bank
  10. muscl car
    21,955
    795
    Jul 8, 2001
    i've got a set of monroe air shocks and were installed 8 years ago and at that time it was around $80 for them
