Need pictures of original seat belts in 70-73 Camaros
Discussion in 'Interior Restoration' started by Battmann, Nov 4, 2007.
  1. Battmann
    Battmann Veteran Member
    705
    Sep 12, 2007
    North Chili, NY
    can someone post some pics of original seat belts in a 70-73 Camaro (mine is a 1972)? the previous owner of my car only left the shoulder belt and one female buckle on the front seats. i searched through the old posts, but pictures are missing so i still have some questions:
    how do the lap and shoulder belts work when used together - are there 2 female ends (one for each buckle) or do they both connect to one buckle somehow?
    are the front male lap belts supposed to be retractable?
    is there a third middle seat belt set in the back or just the two?
    can anyone tell me what lengths (inches) the belts are for each seat - i assume front and back are different?
    thanks for any help.
  2. ParkerRS
    ParkerRS Veteran Member
    734
    May 26, 2006
    Dallas, Ga.
    The rear only has belts for 2 passengers, I'm not sure but I think retracters were an option but like I said not sure. Thats all I can tell you as I have a 73 and they have a one year only type belt system in the front and my 72 didn't have any belts when I bought it and I will probably use an aftermarket set up in it.
  3. unrestored72Z
    unrestored72Z Veteran Member
    255
    Feb 17, 2000
    Sacramento, CA
    late 72 cars had the 73 front combo set up, two males, one female
  4. April81Z28
    April81Z28 Moderator Lifetime Gold Member
    4,423
    Jun 15, 2004
    Eldersburg, MD, USA
    My 72 is an October build. It has the double belts. Two lap belts in the back, lap belts and shoulder belts in the front. Eash belt has a male and female end and there are no retractors anywhere.
  5. tom3
    tom3 Veteran Member
    10,615
    40
    Aug 1, 1999
    ohio
    On my 70 the lower outers have retractors in sleeves, short belts there, no buckles. Inner belts have the buckles, both are about 26 inches long. Rear have two sets only, buckle on inner side belt, is also about 26 inches long, maybe the same as the fronts.
  6. tom3
    tom3 Veteran Member
    10,615
    40
    Aug 1, 1999
    ohio
    If you want I can try to get a couple pictures tomorrow, hard to do in the all black interior though with my junk dig. camera.
  7. old zeder
    old zeder Veteran Member
    1,037
    Feb 21, 2007
    Guelph Ont. Canada
    Here are pics of the belts in have, think they are the 72/73 model, shoulder strap is dated 72, rear seat belts are from a later GM full size vehicle, they should be smaller with a blue GM button same as front, shoulder strap holder is from maybe 73???
  8. Battmann
    705
    Sep 12, 2007
    North Chili, NY
    thanks so much for the responses so far. if anyone can post some close up seat belt pics that would be awesome.
  9. old zeder
    1,037
    Feb 21, 2007
    Guelph Ont. Canada
    Hi Battmann i have posted more pic's above so they may help
    Good Luck
  10. Battmann
    705
    Sep 12, 2007
    North Chili, NY
    thanks for the close up pics.
    those belts look way different than the couple i have. the buckles on mine look larger and have a blue GM button. and the male part is shaped different and isn't retractable.
    i'll probably have to buy a complete set or at least get a few more to match the belts i already have to make a set.
