Need some TPI advice...
Discussion in 'High Tech Retrofits' started by John Wright, Jul 27, 2008.
  1. Knuckle Dragger
    15,136
    1,606
    Nov 2, 2002
    Waddell AZ
    That's why I went with all new GM sensors and actuators.
    Just make sure you ignition 12v source is a true ignition 12v source, and doesn't go away when it's cranking :(
  2. John Wright
    14,714
    216
    Aug 9, 2002
    Rustburg, Va
  3. ULTM8Z
    ULTM8Z Veteran Member
    9,313
    453
    May 19, 2000
    Los Angeles
  4. Knuckle Dragger
    15,136
    1,606
    Nov 2, 2002
    Waddell AZ
    That sucks. I definitely would not run it for the reasons Cali posted. You certainly don't want it in the back of your mind as you're cruising around trying to enjoy the car.
  5. John Wright
    14,714
    216
    Aug 9, 2002
    Rustburg, Va
    My wiring harness came in today from Jim's Performance. I haven't even bothered to open the box yet....still bummed over having to rebuild the motor before trying out his work.
  6. John Wright
    14,714
    216
    Aug 9, 2002
    Rustburg, Va
    Well....I opened the box and stretched out the harness...he has labled it all for me and wrote all sorts of notes about each connection. Now I'll just have to take it one connection at a time and get the car all wired up, mount the computer and wait for the motor to be rebuilt.
  7. John Wright
    14,714
    216
    Aug 9, 2002
    Rustburg, Va
    Speaking of this...since my car is wired for an alternator with an external regular...I need to convert all of that over as well since this motor has the high amp internal regular alternator. Should I use the kit from Mad Electrical for this?
  8. ULTM8Z
    9,313
    453
    May 19, 2000
    Los Angeles
    That's what I used.
  9. ULTM8Z
    9,313
    453
    May 19, 2000
    Los Angeles
    Look on the bright side. It'll be much easier to get into the engine compartment to route the wires and stuff before the engine gets in.
  10. John Wright
    14,714
    216
    Aug 9, 2002
    Rustburg, Va
    Mike what are your thoughts on gutting the air pump vs using a delete pulley?...
