Need some TPI advice...
Discussion in 'High Tech Retrofits' started by John Wright, Jul 27, 2008.
  1. ULTM8Z
    ULTM8Z Veteran Member
    9,313
    453
    May 19, 2000
    Los Angeles
    I don't see why that wouldn't work. I have no idea how these pumps are constructed, but if you can get the pump to just free-wheel then it essentially becomes its own delete pulley.
  2. John Wright
    14,714
    216
    Aug 9, 2002
    Rustburg, Va
    I read over on the third gen board where people have taken the fins and I assume the valves out of them so that they do nothing. I guess I could make a simple flat plate with a gasket to cover the hole in the back of the pump where the line goes out to the diverter valve.
  3. ULTM8Z
    9,313
    453
    May 19, 2000
    Los Angeles
    I figured someone somehow figured out a away to defeat some smog equipment... :crazy:
