Need stagger hole mini starter
Discussion in 'Engine Topic' started by Cardinal, Jan 20, 2012.
  1. Cardinal
    8,275
    28
    Jun 22, 2003
    Endicott, NY
    I bought a high torque mini starter for JD's '83 S10 with a '74 Monte Carlo 350 SBC which has a 168 tooth SFI approved flexplate on it.
    The starter has the straight across pattern BUT the block has the stagger hole pattern.
    We could drill the block BUT he and I would prefer to buy a stagger hole mini starter.
    Can anyone point us to a stagger hole mini high torque starter for a 168 tooth flexplate for a SBC.
  2. K5JMP
    10,216
    8
    Oct 19, 2006
    MORTUORUM VENATOR - Z.R.T.
    Skip White sells a dual pattern one...
  3. gregs78cam
    gregs78cam Member
    51
    May 2, 2004
    Spirit Lake, ID
  4. Cardinal
    8,275
    28
    Jun 22, 2003
    Endicott, NY
  5. markw
    markw Veteran Member
    818
    Jun 6, 2009
    Illinois
  6. Cardinal
    8,275
    28
    Jun 22, 2003
    Endicott, NY
    WOW! $57.90! AND free shipping!
  7. Todd80Z28
    11,495
    222
    Jun 11, 2002
    Northern VA
    That's the typical early 90s Jimmy/S10 4.3 starter, IIRC. It'll turn the small block just fine.
  8. Cardinal
    8,275
    28
    Jun 22, 2003
    Endicott, NY
    JD's S10's V8 is mostly bone stock out of a '74 Monte Carlo. The only modifications to it are an Edelbrock hydraulic lifter cam, Wieand Action+ intake, Edelbrock Performer carb, and Headman shorty headers. So I completely agree that a 4.3L's mini starter will probably turn it right over.
    In fact, I think I have two good one's of those starters in the box of starters in the lean too!
  9. krabben1
    8,159
    44
    May 16, 2007
    ( . Y . )Delco
    Just be very careful with the skip whites starter stud.It doesnt take much to knock it loose,then you have to call and send it back.I love the starter,went in clean,no shimming,sounds great when it starts.Thats my only drawback with this is that you have to wait on the mail.
  10. Show7d3
    Show7d3 Veteran Member Lifetime Gold Member
    334
    Feb 27, 2007
    Manheim, PA
