Nervous panel replacement
Discussion in 'Body Restoration' started by Revin, Oct 5, 2016.
  1. Revin
    Revin Veteran Member
    545
    87
    Aug 31, 2016
    Round Rock , TEXAS
    Ok I will try that when I has gass (pun intended :p)
  2. 80sz
    80sz Veteran Member
    3,170
    416
    Feb 2, 2014
    Buffalo,n.y.
    I'm a rookie welder and have a Hobart ,take my advise if ya want but looks to hot and to much wire making up for the too much heat. Back down to b with a feed of 2-3. Tack the hole with 3-4 burst. That's pretty thick ,you might be better off drilling thru and using copper on back side . I use .30 solid wire and gas at 15. I also use no gas at same speed if not penetrating well. My tacks are never bigger than a 1/8" in size. Going bigger melts the metal. 2 second bursts has ben working for me.
  3. Revin
    545
    87
    Aug 31, 2016
    Round Rock , TEXAS
    I had thought about the wire dia.(0.25) but it seemed to work ok on other projects. Believe me I know about melting the panels...
    Right now I must have gotten something to stick. The panel is staying put without clamps. Ha.
    AND the AMD panel is a good fit at the door at least! :)
  4. John Wright
    14,683
    209
    Aug 9, 2002
    Rustburg, Va
    Gas shielding is not measure in psi, most flow meters are in cfh (cubic feet per minute). Make sure you have the polarity correct for the wire you are using. FCAW(fluxcored wire) and GMAW(solid wire) use different polarity from each other. GMAW uses DCEP(the gun is DC+, or in other words DC electrode positive) while FCAW uses DCEN(the work clamp is DC+).
  5. Revin
    545
    87
    Aug 31, 2016
    Round Rock , TEXAS
    Thanks john. Polarity is correct.
  6. perkalator
    perkalator Veteran Member
    1,025
    89
    Aug 27, 2014
    kennewick wa
    Make sure your getting your shielding gas to the mig gun. If your using weld through primer clean it out of the plug hole before welding. Do not drill all the way through and use a copper backing plate. I run about 14 to 18 psi stargon gas and .35 wire(the wire size is because i got it for free).
  7. Revin
    545
    87
    Aug 31, 2016
    Round Rock , TEXAS
  8. 81 Sport Coupe
    81 Sport Coupe Veteran Member
    246
    Nov 27, 2012
    Batavia, NY
    awesome bodywork! I saw another member got an AMD trunk pan, is that the sheet metal manufacture you stuck with as well? I have to do mine on my 81. I did my inner and outer rockers with AMD sheet metal and the fitment was perfect as well as the quality. I think the AMD trunk pan is around $430 though for my 81.
  9. Revin
    545
    87
    Aug 31, 2016
    Round Rock , TEXAS
    Hey thanks for the kind words!
    Yes I have stuck with AMD parts. I got to say, I did look around for cheaper prices. Guess what, there are others selling AMD parts just cheaper price than AMD factory prices.
    Take your time to look around.
    I am very happy with the fit. Soon the interior will get the knife.;)
  10. Revin
    545
    87
    Aug 31, 2016
    Round Rock , TEXAS
    Hey still hard at it here.:rolleyes:
    I got a new welding helmet and nice jacket. I also had to refill my argon....so I tried a local shop. Guess what?!
    The guy said I had the wrong bottle! I had straight argon, not argon/oxygen mix for my Mig. so we got the correct bottle and cheap I should add.
    Went home to play with the new toys and son of a gun... I can actually weld so much better now !!!:cool: I even impressed myself!
    No where near pro so I won't show any pics yet. but I now have a rear floor pan in and quarter and trunk pan. Front half of floor pan on both sides next! Maybe I should put the taillight panel on someday....
    Broke away from welding to rebuild the differential. So back to welding!!!!:bowtie:
