Neutral safety switch for T56
Discussion in 'Transmission & Driveline Topics' started by C4Racer, Apr 17, 2019.
  1. dave@ztech
    3,426
    712
    Mar 27, 2016
    NY
    If that's the case, check to be sure the choke is working correct, may just need a little adjustment.
  2. C4Racer
    C4Racer Veteran Member
    642
    112
    Oct 26, 2018
    Choke? Haha
    Nope. This is a 525hp 406 with a 750 race demon DP Holley carb and a very big cam. The “choke” is working exactly as designed !
  3. dave@ztech
    3,426
    712
    Mar 27, 2016
    NY
    HAA HA, well that will make cold start a little more of a problem, however, if I had that setup, I would live with the issue, HAA HA
  4. C4Racer
    642
    112
    Oct 26, 2018
    Yes I live with it. Doesn’t take long to warm up. Runs very nicely once warmed up. Couple minutes.
  5. badazz81z28
    16,675
    462
    Las Vegas, NV
    Sounds to me you don’t need a neutral safety switch. I personally don’t have mine connected.
  6. DesmoEd
    DesmoEd Veteran Member
    1,138
    Sep 9, 2009
    Frisco, TX
    I know what you mean, I don't have a choke on either of my carbed cars.
    Same for the neutral safety switch, neither is necessary if you follow SOP as in allow a few extra minutes for a cold start and don't crank the car in gear...
  7. C4Racer
    642
    112
    Oct 26, 2018
    Ya I never would
  8. C4Racer
    642
    112
    Oct 26, 2018
    I did connect the reverse lockout to the brake switch so you have to have the brake on to put in reverse. I like that as a safety to avoid a miss shift while driving
  9. BonzoHansen
    19,387
    757
    Jun 1, 2005
    Scott from Hamilton, NJ
    I did that, change it. It powers it too much, and they aren’t cheap to replace if you wear it out prematurely. And there were a handful of times coming off the highway the RLO energized when i didn't want it too. Ive seen other guys mention it too. I used a n/o momentary switch and relay now.
  10. C4Racer
    642
    112
    Oct 26, 2018
    Switch connected to what ?
