Neutralize Salt
Discussion in 'The BS Topic' started by li0nhart123, May 23, 2010.
  1. li0nhart123
    li0nhart123 Veteran Member
    737
    Jan 20, 2008
    British Columbia
    What do you guys/gals do to stop road salt from eating the undercarriages of your rides?
    I don't drive my camaro in winter but my truck gets coated with calcium chloride, sodium chloride and magnesium chloride every winter.
    Other than washing it regularly is there something else to be done?
    I've been reading about baking soda in the wash water.
  2. ATM
    ATM Veteran Member Lifetime Gold Member
    2,265
    Oct 10, 2009
    Morris, Illinois
    Is salt acidic or alkaline? I never knew that.
  3. Mark80Z28
    Mark80Z28 Veteran Member
    1,457
    Aug 16, 2006
    Ohio
    I've left my oil leaks unfixed. They've left the undercarriage with a nice thick coat of rust preventing crud! ;)
  4. li0nhart123
    737
    Jan 20, 2008
    British Columbia
    I don't think it is either. I think acids are formed during the corrosion process though.
    It is likely that these acids (if they exist) could be neutralized by baking soda...but I'm just guessing.
  5. ATM
    2,265
    Oct 10, 2009
    Morris, Illinois
    Baking soda is alkaline, it can be used to lower PH.
    I'm not sure if it would work or not though. Or even how you would do it. I think your best bet is to wash it every now and again.
  6. Lowend
    14,897
    413
    Mar 25, 1999
    San Jose, CA, USA
    ... live in California
  7. krabben1
    8,159
    44
    May 16, 2007
    ( . Y . )Delco
    7 gallons of sloppily applied POR-15.
  8. Twisted_Metal
    26,731
    831
    Salts are water soluble... wash it off.
    Salts are formed from acidic and alkaline components.
    The salts are neutral but they ionize back to acidic and alkaline components when they are in solution.
    Dry salt doesn't hurt metal..... Just add a little bit of water (or humidity in the air) and you get corrosion.
  9. Cardinal
    8,270
    26
    Jun 22, 2003
    Endicott, NY
    The best way to prevent the steel/iron from rusting is to coat it so that oxygen can't get to it. I had a 62 Chevy 40 series truck that I built into a ramp truck. After clening up and repairing the frame, I coated it with Extend (a Locktite procuct that chemically changes "fluffy" rust into a polymer) and then painted it with Rustoleum Gloss Black paint. YEARS after I sold the Gray Ghost, I found it in a junkyard and that frame looked like the day I coated it!
  10. Gary S
    22,118
    659
    Like a wise Twisted_Metal once said, "Salts are water soluble... wash it off."
