New Alternator-Old mounting bracket doesn't fit?
Discussion in 'Troubleshooting & Diagnosis' started by wdstamper, Dec 29, 2017.
  1. FlaJunkie
    6,247
    183
    Mar 24, 2001
    Rockledge, Florida
    I bought a 12SI alternator from these guys. It works very well in the new harness and is internally regulated. It is beefier than the original alternator and provides better performance over a "one-wire" racing alternator for street use. It costs about $170. It outputs 140 amps. There is a higher output one available. You need to decide how many amps you need. Do you have electric fans or a high amp sound system? If not, the 140 amp model is fine.
  2. wdstamper
    wdstamper Veteran Member
    141
    May 17, 2014
    Florida
    I looked up the Lester 7137 number and cross referenced to the replacement model which has the wrong bolt pattern for my car. I also found a Wilson 90-01-3109 allternator that should bolt right on assuming the picture is correct. Thanks for everyone’s help.
    Walt.
  3. McCune
    McCune Veteran Member
    998
    169
    Aug 22, 2015
    st.george utah
    7137-3 15 SI . What year are you working on? That Wilson # crosses to a 7137-3. Delco #s are 1101044, 1101066, 1101088, 1101093, 1101442, 1105186, 1105342, 1984271.
  4. wdstamper
    141
    May 17, 2014
    Florida
    McCune:
    My car is a 1981 z28. Is that the wrong one? Thanks.
    Walt
  5. McCune
    998
    169
    Aug 22, 2015
    st.george utah
    I believe your car was option with the higher amp 15 SI alternator. The original alternator you posted appears to be a original unit. it even had the plastic clip that is next to the battery stud. I would put that same 15SI back on your car and not try to hack a 12 SI in its place. Did you also notice that the adjustment bolt is a 10mm bolt and not a 8mm?
  6. wdstamper
    141
    May 17, 2014
    Florida
    I did not. I went back to the auto parts store and retrieved my old alternator. I think at this point I’m going see if I can have a local shop rebuild the unit. Thx.
    Walt
  7. Dave Nelson
    Dave Nelson Veteran Member
    4,232
    1,958
    Dec 19, 2003
    Vineland N.J USA
    That would be the best option.
    FlaJunkie likes this.
  8. Damon
    Damon Veteran Member
    12,939
    21
    Nov 16, 2000
    Philly area
    Yeah, that's a 15SI or 27SI alternator. Despite their higher designation number, they are basically the same operating principles as the common old 10SI series alternators. Physically larger case and higher output rated, but basically the same electrically-speaking and still with exposed cooling fan blades.
    The 12SI is a later design alternator (and a direct bolt-in for any 10SI alternator, but NOT for a 15SI or 27SI) with enclosed plastic cooling fan blades, much better low RPM performance and with amperage ratings of various models comparable to the old 15/27SI. This is still all v-belt vintage stuff I'm talking about here- roughly 1985-down.
    The 15/27SI is a bit of an oddball, but if you're going for that vintage look they work OK. If you're building a high RPM engine you should know that they tend to "explode" at high RPMs with some regularity.
    My Malibu came with a 10SI (63A) from the factory that I replaced with a later model 12SI (94A). Doesn't sound like much of an upgrade but it bolted right on and holds onto target voltage like a pit bull even at idle. The plastic cooling fan on the front doesn't look right for my vintage of Malibu but I don't care. It works far better than the stock unit in the real world.
    Last thought- the rear bracket retaining bolt on pretty much any GM alternator serves no real purpose. You can hack the arm off it and run it like it's just a spacer and you'll never have a problem. The attachment arm on yours is absolutely unique to the 15SI/27SI series of alternators and won't fit anything else, as you have learned.
