New Engine ....... going even bigger cubic inch sbc
Discussion in 'High Performance Modifications' started by muscl car, Nov 27, 2019.
  1. muscl car
    21,729
    648
    Jul 8, 2001
    High Desert of Hesperia Calif
    Going to a 427 sbc that should make easily 600 plus hp / 590 tq
    Dart Little M 4 bolt block
    Scat 4.000 stroke 4340 forged crank
    Scat 6.000 4340 forged H beam rods
    Forged pistons ( should be 11.4 comp with my 64cc AFR Cyl Heads)
    Howard's hyd roller 600 lift , 251/259 dur @ .050 112 LSA
    Will reuse the top end of the old engine ....
    AFR cyl heads
    Edelbrock super Victor
    Wilson tapered 4 hole spacer
    roadrace2 and buick skylark like this.
  2. Zspoiler
    Zspoiler Veteran Member
    3,267
    266
    May 6, 2012
    Federal Way, Washington
    That sounds fun .It will have quite a cackle to to it.
    buick skylark and muscl car like this.
  3. badazz81z28
    16,923
    502
    Las Vegas, NV
    Hydraulic roller is a nice touch
  4. camaro71/holland
    1,236
    85
    Aug 27, 2003
    The Netherlands
    Nice! Congrats :bowtie:
  5. CorkyE
    10,381
    472
    Guess I missed something, thought you already had a 427 sb from several months back. That should make the tire bill go up.
  6. G72Zed
    G72Zed Veteran Member
    1,195
    276
    Sep 8, 2015
    I thought you just built/finished your 600hp/ 406ci? I guess your looking for more TQ, (lol, aren't we all most Times). Or, your not happy with the dyno results and 1/4 mile performance & ET.
    I would look into the final compression with your new 434 build, given the regular HG cc with flat tops and a 64cc your 406 was around 11.55CR, if everything is staying the same, your up to 12.25CR, unless your on race gas, then no worries.
    Are you good with using an oil ring support rail with the short 1.000CH pistons. I like to stay away from those if possible, just difficult with that short of a CH piston.
  7. dcozzi
    dcozzi Veteran Member
    3,092
    422
    May 1, 2002
    Phoenix, AZ
    You will be nice and lopey with that cam. I have a .568 hyd. roller in my 406 and it is pretty rowdy already.
  8. CorkyE
    10,381
    472
    With 112* LSA, are you looking at EFI in the future? Certainly the best thing I've done to my engine.
  9. frankz
    frankz Veteran Member
    2,090
    13
    Aug 24, 2009
    Illinois
    If I were to build a small block from scratch I would go 18 degree for Sure.
  10. G72Zed
    1,195
    276
    Sep 8, 2015
    A 434 SBC with a 4 inch stroke and a 251 dur @ .050 cam with a wide 112 LSA, I say it will be on the tamer side of idle characteristics, and the wrong cam, but if going FI, it may be great.
    The "best" overall "mild" cam I have used is 252 @ .050 on a 112 lsa, w/10.5cr, but is 100 cubic inches smaller?
    muscl car likes this.
