New hydraulic clutch master bracket available
Discussion in 'Transmission & Driveline Topics' started by Scarebird, Mar 1, 2014.
  1. Scarebird
    Scarebird Member
    38
    Apr 21, 2013
    Bothell, WA
    I was not happy with the choices to mount a hydraulic clutch master, so I designed and had laser cut my own. This uses the excellent Wilwood master - this includes remote reservoir attachment for a very good price.
    You will need to currently modify the pushrod; we will offer a replacement rod in the future; I attached some pix. Will offer the 1st batch (only 4) at $29 plus shipping. Later batches will be more. Email me direct at m@scarebird.com with questions
  2. 351maverick
    351maverick Veteran Member
    3,614
    390
    Aug 11, 2010
    erie, PA
    does that even work with such a steep angle?
  3. Scarebird
    Scarebird Member
    38
    Apr 21, 2013
    Bothell, WA
    yes, why wouldn't it?
  4. grzewnicki
    3,388
    148
    Dec 9, 2009
    Gordon from Jacksonville Fl
    Maybe we are missing something here...I don't have nor have I ever thought about putting a hyd clutch on my car but even I am wondering about the angle. Doesn't the pushrod from the clutch pedal come out almost horizontal from the clutch pedal, and the slave cylinder is mounted at about 45 degrees down?
  5. Scarebird
    Scarebird Member
    38
    Apr 21, 2013
    Bothell, WA
    no, it goes down at about a 30* angle for best engagement for hydraulic - I'll pot a pic of the rod/lever engagement to show this later.
  6. grzewnicki
    3,388
    148
    Dec 9, 2009
    Yea, post up a pic, I'd be interested in seeing how that works. In my previous post, I was just going off the angle of the stock pushrod to Z bar angle, which is just a few degrees down.
  7. Scarebird
    Scarebird Member
    38
    Apr 21, 2013
    Bothell, WA
    This is a mockup of the setup; we machined the shaft to barely fit inside the master, so it would give us the exact angle needed for maximum efficiency.
  8. XxWickedz28xX
    XxWickedz28xX Veteran Member Lifetime Gold Member
    5,980
    May 22, 2001
    Carmel, NY
    Will this work with the stock hydraulics from a LT1 sourced t56?
  9. Scarebird
    Scarebird Member
    38
    Apr 21, 2013
    Bothell, WA
    Wilwood sells several different masters, match the stock GM master diameter and you should be good...
  10. walt03
    walt03 New Member
    Apr 8, 2014
    Brentwood, TN
    work on a 1975 Firebird?
    I have a 75 Firebird with 400 pontiac and 4 tube headers.
    What would I have to do too make it work on that. Same as a 75 Camero?
    Thanks,
    Walt
