New main bearing wear
Discussion in 'Engine Topic' started by CoastieJoe, Oct 15, 2019.
  1. CoastieJoe
    CoastieJoe Member
    46
    Jul 29, 2017
    My SBC is cursed! I've almost had it finished twice but keep finding something. On this tear apart I noticed that the new main bearings had wear on them even though the engine had never been run. Just cranked on while rebuilding. It looks like the flat colored coating is already wearing off. Is the wear in the pictures normal? And it seemed to be get worse towards the front. And yes I put breal in oil on them during install. The pictures are in order from front to rear. Thanks guys.
  2. camaro71/holland
    1,236
    85
    Aug 27, 2003
    The Netherlands
    Have you checked and if so what are the clearances?
  3. CorkyE
    10,376
    471
    Another simple thing; how easy/hard does the crank turn when it's torqued down? Just the crank only, no rods or pistons installed. It should not have any spots where it's harder or easier to turn.
  4. budro6968
    budro6968 Veteran Member
    3,269
    522
    Apr 2, 2016
    Jax Florida
    Should turn over like butter with one finger. Those look like they were spun dry. Definitely check oil clearance with some plastic gauge.
  5. xten
    xten Veteran Member
    2,944
    1,715
    Sep 24, 2014
    Pittsburgh, Pa.
    Was assembly used?
  6. CorkyE
    10,376
    471
    Yep, I should have asked about assembly lube, think xten meant that. I'm an old fashion Lubriplate guy.
    xten likes this.
  7. CoastieJoe
    CoastieJoe Member
    46
    Jul 29, 2017
    I used assembly lube and I checked the clearance with plastic gauge and it was good. The crank spun freely when I had it in.
  8. Dave Nelson
    Dave Nelson Veteran Member
    4,397
    2,243
    Dec 19, 2003
    Vineland N.J USA
    Could you turn the crank by hand?
  9. COPO
    17,866
    750
    Incorrect clearance.
  10. czizza
    czizza Veteran Member
    1,026
    68
    Jan 8, 2004
    N. Massapequa, NY, USA
    If you plasti gauge it and it checked out then maybe your align center bore could be off. Do you have a machine ruler so you can see if you are good front to back.
