New main bearing wear
Discussion in 'Engine Topic' started by CoastieJoe, Oct 15, 2019.
  1. tom3
    tom3 Veteran Member
    12,031
    346
    Aug 1, 1999
    ohio
    You didn't by any chance put anything on the back side of the bearings on final assembly? Anything?
  2. cadillac_al
    cadillac_al Veteran Member
    842
    87
    Apr 22, 2015
    Maine
    That sounds good enough to me. It's been a long time since I had a chance to inspect some low mileage bearings but I am always surprised how scuffed up they looked after only a few miles. I have never taken out bearings that looked pristine and new. I kinda think that's how they break in/wear in. I have always used the red slippery assembly lube since the 80's, can't remember the name of it right now. I think you might be ok after all.
  3. camaro71/holland
    1,239
    86
    Aug 27, 2003
    The Netherlands
    Main bearings on the crank out of round? How did the old caps look like?
  4. CoastieJoe
    CoastieJoe Member
    46
    Jul 29, 2017
    The caps look good and I just re measured all the bearing clearances and they are at .002. I'm thinking about running them. Anyone think I should get new ones? Also just to try something new what's everyone put on their main and rod bearings when installing?
  5. jeff swisher
    jeff swisher Veteran Member
    1,385
    418
    Apr 26, 2018
    Yukon Oklahoma
    Those pictures of the bearings in the block look very dry and clean to me.
    NO way I could make my bearings look that oil /lube free unless I took them out and solvent cleaned them and solvent cleaned the block as lube will be dripping on stuff.
    I want to know what lube you used and did you clean it off for the pictures???
    I use driven assembly lube or Lucas or the EOS and sometimes just Gibbs BR oil.. never an issue with any of it but it leaves everything oily. My bearings look like new after a few turns.
    I think your lube is poor.
    Buddy used WD40 once..Parts store told him he did not need anything on the bearings.
    WOW!
  6. CoastieJoe
    CoastieJoe Member
    46
    Jul 29, 2017
    I did clean them off to better show the wear.
  7. badazz81z28
    16,991
    522
    Las Vegas, NV
    For an engine that’s never been run?
  8. CoastieJoe
    CoastieJoe Member
    46
    Jul 29, 2017
    Yes never run
  9. 77 cruiser
    77 cruiser Veteran Member
    542
    25
    Nov 17, 2006
    Frostbite Falls MN
    I'd think about sending it out to be line honed & get the crank checked for straightness.
    I had one like that but it was run, took it down at 15000 miles copper showing in some places on the mains.
  10. G72Zed
    G72Zed Veteran Member
    1,202
    280
    Sep 8, 2015
    The wear pattern looks within reason, and perhaps turned too many times on the dry side. If you could turn easy by hand with the mains TQ'd down you will be OK.
    IF you can, set the lower mains in place only, lay in the crank, and toss a dial indicator on the middle main (3rd) it will tell you the run-out if any, repeat on the others to see what comes up.
