New Refrigerant in 2013+ vehicles is very dangerous
Discussion in 'The BS Topic' started by Aceshigh, May 20, 2014.
  1. Twisted_Metal
    26,891
    907
    But, CO2 is only one oxygen atom away from toxic carbon monoxide!
    (Or one carbon atom from an extremely flammable substance... OXYGEN!!! :eek: )
    These chemicals are pretty safe when they are confined to their working environments or released under normal temps and pressures.
    It's the combination of heat, oil, atmosphere AND the refrigerant which can lead to ugly reactions which are not friendly to us carbon-based life forms.
  2. Aceshigh
    26,757
    Apr 9, 2001
    Boondocks
    Front end collisions with any kind of system fire ignited concerns me with that necrosis and breathing into the lungs. Never knew that was that deadly before, and its not an unimaginable thing to happen.
    Especially if ur suckin outside air into the cabin via the system.Thats a death sentence even if you walk away it seems.
  3. 91chevywt
    91chevywt Veteran Member
    206
    May 27, 2008
    South Jersey, NJ
    I can't comment on an R134a fire, but if the studies of this refrigerant are correct I would be concerned for Fire/EMS that may be exposed to a HFO-1234yf fire. The article suggests that only a hot surface is necessary to trigger a fire which would release truly nasty HF.
  4. Joekool
    Joekool Veteran Member
    5,919
    35
    Feb 4, 2002
    Hollister CA USA
    Has anyone been around a modern car on fire? All the plastics that are used in cars these days will overwhelm anyone in seconds. And these are nothing special fires, just an open air slow roast car-b-q type fires that belch out clouds of toxic smoke.
    This case is real easy to solve, don't route A/C lines near exhaust parts. They don't say in the article at what temp. it takes to cause all those nasty things but usually it requires very high temps (hence the hot turbo).
  5. mgoad1971
    mgoad1971 Veteran Member Lifetime Gold Member
    2,472
    Jul 29, 2011
    Houston, Texas
    The entire industry is forced to swap MTBE for Ethanol and nobody bats an eye....
    See signature below....
  6. Camaro75LT
    Camaro75LT Masshole Staff Member Lifetime Gold Member
    6,651
    89
    May 17, 2001
    Boston-ish
    Name this car
    Total burn time was about 7 minutes and that is the radiator melted in the front. I'm sure the toxic smoke traveled pretty well. How much more dangerous is adding a neurotoxin?
  7. danbrennan
    danbrennan Veteran Member Lifetime Gold Member
    3,467
    255
    Mar 13, 1999
    Brighton, MI
    Odd, 10 years ago I heard everyone was going to switch to CO2 for vehicle A/C systems. I don't work with those guys anymore, but I wonder what happened to that. Europe in particular was supposedly eager to make that switch.
  8. norwood
    norwood Veteran Member
    290
    Apr 6, 2007
    Bartlett, Il
    OXYGEN is not flammable, it is an oxidizer. An oxidizer is necessary for combustion but by itself it will NOT burn.
  9. rwild1967
    rwild1967 Veteran Member
    251
    Aug 11, 2009
    Look behind you!
    What a silly thing to say. Oxygen alone (and as far as I know neither will any other element) will not combust, because there must be something to react with. Didn't you pay attention in school? The fire triangle? You have to have fuel, oxygen, and heat.
    Edit: post above was edited to make more sense.
  10. mgoad1971
    2,472
    Jul 29, 2011
    Houston, Texas
    There's also the fire tetrahedron.....
    .[​IMG]
